Electrical issue
Discussion in 'General' started by phatchopper300, Sep 30, 2017.
  1. phatchopper300
    phatchopper300 I just wanta ride
    Morganton, (Western) NC
    08 k-9 Dakota spedo, RIP Kit gen. one 585 cam 2 1/2 forward contr
    Mike
    Ok now having issue electrical this time it's dealing with the CB keeps tripping during ridding so it's not charging battery then battery dies then bike shuts down. Not sure where to start. I guess start on grounds then each system I have1st gen rip kit 08 efi k9
    Sent from my SM-N950U using Tapatalk
  2. phatchopper300
    Mike
    I replaced 'vr about 6 months ago with cycle electric
  3. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    What's the voltage when charging?
    It's possible the circuit breaker just isn't any good
  4. phatchopper300
    Mike
    13.8 volts with bike at idle. I might as well replace CB rule that out
  5. phatchopper300
    Mike
    Is there a way to test CB
  6. phatchopper300
    Mike
    CB is about 6 months old also reset button type
  7. Th3InfamousI
    Texas
    Try running a fuse do you have a dedicated fuse for the RIP kit connected to the battery?
    Check the ground on the VR it's possible it gets dirty as its grounded via the bolt into the frame.
  8. phatchopper300
    Mike
    Yes I will be checking vr ground
  9. phatchopper300
    Mike
    Not sure fuse dedicated for rip I do have efi dedicated
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Some of us replaced the CB with this from Pep Boys, 40 amp fuse n holder
    bdm7250 likes this.
  11. Th3InfamousI
    Texas
    You should have a dedicated 30 AMP fuse for the RIP!
    The VR should have it's own dedicated fuse or breaker.
  12. phatchopper300
    Mike
    Yes I had a brain fart you are correct I do have that
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I think you mean 20 Amp
    dentdude36 likes this.
  14. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    dentdude36 and BWG56 like this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :cry:
    bdm7250 and dentdude36 like this.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :nonod::boing:
    bdm7250 likes this.
  17. bdm7250
    bdm7250 Guru
    Doug
  18. phatchopper300
    Mike
    Another ? the relay for efi looks like horn relay what should the voltage be on relay(25 amp). The relay gets very warm during operation I know it has power to it with engine running I have had to replace it before Want to make sure it's the correct amperage Just wondering if that is flipping the circuit breaker
    chubs likes this.
  19. phatchopper300
    Mike
    Bump
