EHC issue or turn signal control board?
Discussion in 'EFI Topics' started by cajun1, Jun 19, 2017.
  1. cajun1
    cajun1 Member
    Full Member
    Eunice Louisiana
    2005 Bigdog Bulldog
    John
    Having an issue which seems to be no power to the right side control switches on my 05 bulldog, The left side switches all work fine. I was wondering if this could be an EHC issue are just an issue with the right side control board and is there any tricks to test which one it might be?
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Pull the hand control apart and jump the wires to see if you get the functions to work that are not working now
    bdm7250, chubs and TapioK like this.
  3. shansel88
    shansel88 Member
    Full Member
    Jacksonville FL
    2004 Chopper
    Sam
    That is the tightest wiring on the bike- has connector that plugs into harness under the tank and it stretches when turning bars. Just verify the connector under the tank is connected. Just my opinion.
    Billy413 and chubs like this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    No wires should be stretching when turning the bars
  5. cajun1
    cajun1 Member
    Full Member
    Eunice Louisiana
    2005 Bigdog Bulldog
    John
    Thanks for the info.
    chubs likes this.
  6. bdm7250
    bdm7250 Guru
    Supporting Member Full Member
    Hamilton Ontario Canada
    Doug
    :agree: Prolly best place to start.
  7. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    If the board is bad, send it to me and I'll see if I can fix it.
    chubs likes this.
  8. Billy413
    Billy413 Member
    Schuylkill haven PA
    05 ridgeback
    Yes, check for power and ground at the switch wires on the bars, if you get no ground or power then pull off tank and check if it's unplugged.
    chubs likes this.
