Eatin pads
Discussion in 'Brakes / Suspension' started by Big Daddy 72, Jun 9, 2016.
  1. Big Daddy 72
    Full Member
    Bentonville, Ar.
    2006 Mastiff 2008 k9
    Big Daddy
    I changed out my rear brake pads (they were gone disc had ground into the caliper.
    I split the caliper to dress the alum. Mess that the disc made when it dug into the caliper.
    I reassembled with the little spacers and bled the rear brake. I added dot 5 brake fluid, wich was blue in color. The fluid that was in the res. was clear.
    Went for a ride with my bro, brake worked fine but could smell it at a stop and the disc was super hot, couldn't feel any drag but it was eating pads.
    Anyone run across this before?
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    You're Pistons could be seized in the calipar not letting them return. Or there is pressure not releasing in the line or the calipar assembly is mounted incorrectly. Check it out closely.
    chubs and pknowles like this.
  3. HMAN
    HMAN Just like to ride
    Supporting Member Full Member
    Ks
    Harry
    Yup, rebuild ur caliper. Pistons not returning. Had it happen on the Pit.
    chubs likes this.
  4. Big Daddy 72
    Full Member
    Bentonville, Ar.
    Big Daddy
    Who did you get your rebuild kit from?
    chubs likes this.
  5. HMAN
    Ks
    Harry
    Crap, been so long ago I cant remember. Check with Performance Machine. They are OEM. I wanna say kits are like $12-20. Pull the numbers off the caliper and you will get the correct kit. Pull the pistons and buff them shiny, clean the cylinder walls, install new seals, Easy peasy...
    http://www.jpcycles.com/product/242-321
    #5 HMAN, Jun 9, 2016
    chubs likes this.
  6. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    Same here
    chubs likes this.
  7. Dragonslave
    Salisbury, NC
    Dustin
    I got mine from Curtis (@KaptinAmerika)
    chubs likes this.
  8. HMAN
    Ks
    Harry
    FWIW, I have 2 sets of 0052-3002. I ordered the wrong set the first time and they told me to just keep these. So if ya find that's the number you need, lemme know and they are yours.
    (The kit number for the Pit is 052-2400, if this helps)
    #8 HMAN, Jun 10, 2016
    BWG56 and chubs like this.
  9. Big Daddy 72
    Full Member
    Bentonville, Ar.
    Big Daddy
    :D
    Very cool of you dude to offer!! ;) what a guy!! Kind gesture...
    Warms the heart doesn't it.....it's guys like you that make this fourm a brotherhood. Thanks pal!
    chubs, BWG56 and HMAN like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :old2:Sounds like we're gettin close to a group hug again, come on bring it in[​IMG]:oldlaugh:
    chubs likes this.
  11. Sven
    Sven Well-Known Member
    Full Member
    building one
    1. Oil boils, right? What remains in that gap of air? Water.
    2. Which is heavier, oil or water? Water.
    3. Magnetically speaking, we cannot separate heat from chemRe you move those molecules.
    4. What happens next is water lands under this 4-square looking rubber ring called a quad ring.
    5. Not changing the oil every so often, not like now since the bike came out 12 years ago give or take.
    6. There is a chemical like crystal formation that takes up the space in the groove around the quad ring.
    7. The quad has memory so it wrinkles with the piston is the one direction. Piston pulls back; for every action.
    8. The crystallization under the quad ring cannot let the square move back to square, pull the piston back etc.
    9. The piston stays where it's at upon pressure release, pad has no way to retract from the disc, stays where it's at, rubs the material off, heats disc.
    10. Make sense?[​IMG]
    Signed,
    NOLTT
    cdogg556 and heybaylor like this.
  12. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Very good explaination Sven!:old2::cheers:
