Eastwood internal ceramic coating
Discussion in 'Performance' started by Jersey Big Mike, Feb 11, 2019.
  1. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    bigkelk9 likes this.
  2. 41bigdawg
    41bigdawg Let the Big Dawg eat !
    Portland, Tennessee
    2007 Big Dog K9, 2012 Heritage Softail, 2018 Honda 250 Dirt bike
    Robert
    Dang Mike, are your pipes getting that hot? I haven't used the ceramic coat but have used the lava wrap on my dirtbike and it works good by itself.
  3. Big D Florida
    Supporting Member Troop Supporter
    Ceramics run cooler, but the price may burn a little.... but good thermal protection can be achieved by spraying the inner walls (naffles out) of the (new) pipes with white hi-temp paint, at much less cost.
    -Big Doggin on a budget.
  4. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Eastwood is supposed to make a superior product, idk, I used their paint and wasn’t too inpressed after about a half a year... jmo... but good luck on the ceramic coating.
    Big D Florida likes this.
  5. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    The pipes have a tendency to rust under the wrap...
  6. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    If your going to ceramic coat send them off to jethot, pipes will run you about $250 but they will do inside and out and you won't have to wrap them. Lifetime guarantee too
  7. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Just trying to get rid of annoying heat sources when I ride.
  8. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    that was of course the other choice.
  9. Th3InfamousI
    Texas
    Yea, cause to get a good bond you'd have to blast the chrome off and rough up the surface. They blast your pipes and coat them and you can do a silver finish....
    After all the time and materials DIY takes a lot of time and you'd probably only save $100, which is nice but quality won't be the same and not worth the $100 savings.
    Me personally, I would definitely use this stuff on my Jeep but not the bike.
    Also it doesn't state anywhere but I bet you need to cure this stuff and I don't think you can fit your pipes in your oven haha. Reviews seem to indicate you need to cure it.....
    #9 Th3InfamousI, Feb 11, 2019
  10. RCAdd1ct
    RCAdd1ct JAFO
    Richardson, Texas
    '06 HD SG custom and '12 Duc MTS 1200 S Touring
    I went jet hot on the Harley. They were perfect. Not a blemish on them. But damn did it cost!
    They still look great and it has been over 5yrs.
    They did inside and outside.
  11. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    I've had coated pipes from Jet Hot, wrapped pipes and regular chrome. I notice the wrap stays a TINY bit cooler plus it won't melt a pant leg or boot as quickly. The jet hot/chrome is about the same to me really and I had a chic melt her toe on a set of jet hot pipes leaving a nice rubber burn that was next to impossible to get off. Bottom line--pipes are hot, so go with the look you want, otherwise I don't think it's worth the $$$.
    PacoPetty likes this.
  12. Reddickracing
    Reddickracing Active Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
    I have used Jet Hot and HPC coatings on my race car headers, both were great. Inside and out. Headers on my car now been on there 10 plus years
  13. PacoPetty
    PacoPetty Well-Known Member
    Martinsville,VA
    2006 Bigdog Pitbull
    Andy
    I was thinking the same thing!
  14. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Holds a lot of heat in and will crack pipes and/or ruin the chrome. If you have a area that is too hot for your foot wrap that. Too hot check the carb. :2cents:
  15. JB105
    JB105 Member
    Wellsville Ny
    2006 K9
    Jeff
    I agree! Most people think lean conditions cause the pipes to change color(blue/gold) but in reality it’s a rich mixture that causes it.
    Reddickracing and PacoPetty like this.
  16. kickstart
    TN
    Pat
    My experience is blue is rich and gold is lean however I believe it has a lot to do with where you ride such as city stop and go compared to very few stop lights and signs.
