Do you park your dog in nuetral?
Discussion in 'General' started by Gas Man, Feb 25, 2008.
Do you park your dog in Nuetral?
  1. Yes, everytime
    37.5%
  2. Yes, if parked for a longer duration
    2.7%
  3. No, don't worry about it.
    10.8%
  4. No, why?
    11.5%
  5. Yes, but not when worried about rolling away.
    37.5%
  1. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    2X :up: This is the hardest bike I've ever had to get into natural. Getting the gas out of the carb is also a good idea because it will varnish up quick and plug things up.
  2. ksmike
    ksmike Active Member
    NE Kansas
    2010 Bulldog, 2001 Harley Deuce, Yamaha YZ250F
    Mike
    The relay that I used was a standard late model Big Dog horn relay, I think I bought it from bigdogpartsking. You could even use the existing horn relay if you don't mind losing the horn function. (who likes the mo-ped horns anyway..)
    A 12VDC SPDT relay will work ( very easy to find at auto parts store). I liked the horn relay because it already had leads on it and a mounting bracket built in to the base.
    I can work on a wiring diagram , but it will be a few days as I am going to be out of town for a while..
    Its a simple circuit, that uses the relay to open the starter solenoid trigger wire when the neutral light is off.
    :up:
  3. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Bill, sounds like there is something not right with your tranny or clutch? My -08 goes to neutral from 1st or 2nd like a "riffle lock". click, click...
    Let Andrew tune your tranny, he only charges like 400 for the whole rebuilt! Money well spent?
    Tapio
  4. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    When I had the OEM kickstand, I never parked in gear. Now that I have this new one from Arlen Ness, I park in gear every time. I just dont trust. I ve seen my bike slowly creep forward while idling. Luckily I was there right beside it. It looks good and is at the same angle as the original. Its just the swivel point bolt is very smooth and easy to swing.
  5. BadDawg Bill
    Deltona fl
    Ya, we have 2 different setups. The belt drive didn't help so the only way to get it in neutral is with my hand with the bike off. Tried resetting the linkage, clutch and all that. It's starting to leak oil from the tranny so soon it will go to Andrew... The bike will go into neutral when up shifting real easy but not at an idle.
  6. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    My tranny has also been just rebuild and it does NOT goes into Neutral while idling... it never has been... the trick is to roll the throttle a bit and it gets into Neutral easy :up:
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Your really close so try this,
    Instead of backing off 1/4 turn, get a good feel, meaning turn it in and touch the throw out bearing a couple times to get the feel, and then touch and ever so slightly back off, maybe 1/16 turn instead, take note to where the alan wrench is pointing and make sure when you tighten the locking nut on the clutch rod that you DO NOT turn the alan wrench.:whoop:
    I have the soft pull balls and ramp but I did not use the 9 plate clutch, still have original clutch in.
    francoblay1 likes this.
  8. francoblay1
    K9 (2006)
    Franco
    :2thumbs: :cheers:
  9. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    Neutral is for Pussy's and Sweden!!!!:D
  10. francoblay1
    K9 (2006)
    Franco
    X2 :up:
    :roll::roll::roll::roll:
