dead dog
Discussion in 'Help Wanted' started by Mike Wilson, May 4, 2019.
  1. Mike Wilson
    Mike Wilson New Member
    northern ca.
    06 mastif
    willy
    I have a 06 Mastif when I turn the key on nothing. I have checked the switch cleaned all conections to ground ,batt,plugs, ect. I left the key on while I checked things out and walked away and power came up. The bike seamed totaly fine but it went out as fast as it came up. No power to anything.WTF
  2. pauldeepsea
    California
    Paul
    Dumb question, have you checked the battery?
    Load test ?
    Clubba likes this.
  3. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Could have a bad key switch, happened to me a few years back.
    bigkelk9 likes this.
  4. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Do you know if you have the original ehc?
    Clubba likes this.
  5. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    My money says switch for sure... I have seen it a few times on them factory switches and them cheap replacement tractor supply switches.. like physically seen it
    Clubba likes this.
  6. bdm7250
    bdm7250 Guru
    Doug
    #6 bdm7250, May 6, 2019
    Clubba and bigkelk9 like this.
  7. bigkelk9
    07 big dog k9
    Kel
    That’s how I would go if my bike was set up that way. The factory ones were crap, supposedly the redesigned ones from D&D are better...
    Clubba likes this.
  8. SEAL-rider
    SEAL-rider Active Member
    Lifetime Supporting Member
    Del Mar, CA
  9. roadie1389
    roadie1389 Well-Known Member
    TX
    The new 5th gen's work just fine and you get 2 keys. The only thing is these where designed for on/off and and accessory but they cut off the 2 leads and shrink wrapped them, so you have to turn it an extra click to turn it on. (I have one) but the key never falls out. BTW - There are more combinations with this setup so less chance somebody else has your key.
    cdogg556 and 41bigdawg like this.
  10. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I didn't even know that there is a 5th generation key switch available, I was riding Fri night and when I got home I went to shut my ignition off and looked down to see my key was gone! :eek: I guess it's time to upgrade!;) :D
    bdm7250, speedball jr. and Unsprung like this.
  11. Mike Wilson
    northern ca.
    06 mastif
    willy
    Thank you all for the response I was really feeling the switch was the problem so i tested it with an ohm meter and it seemed to test good.
    But after 11 years i'm thinking it could be worn out. Ill try to find one. Thanks
  12. roadie1389
    TX
    Thats why i have a new switch
    cdogg556 likes this.
  13. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    And that's why I attach mine to the spark plug wire.
    cdogg556 and knothead like this.
  14. knothead
    knothead RIGID4LIFE
    Tennessee
    2 2004 big dog ridgebacks
    knothead
    Yeah i do too...ive seen this happen to people more than one...plus i care a spare in my wallet just incase i forget to hook it up to the spark plug wire
  15. Sven
    Sven Well-Known Member
    building one
    After how many years copper meets arc with said wall switch in said house? Test good tests goodenuff for me. So if I may interject a few mental notes:
    1. Leaf Blower - in hand, turn it off, move the line, pick the blower back up an nothing. Walk to the wall and note plug is still secure from A to B. Split the blower apart, check on/off switch and checks good. Go to the commutator and sand the copper clean with fine grit sandpaper if not scotch-brite. Assemble blower and toggled switch. Return to the backyard and blow away.
    2. Motorhome Ground Wire - Have the engine cover off, pour fuel down the carb, turn the key and no start, but an arc made that caught out of the corner of my eye. It was the frame strap to engine. Remove ground strap, file both contact points till I see fresh metal(s). Engine fires right off.
    Take my empirical knowledge over to here on this thread, walks me up to the key switch and sanda contact points with a straight edge razor. No wait, OP says switch is good. Unless I make a visual and black arc be the clue. I'd then find said strap from frame to engine, engine to battery post. I'd then find the end of said strap or cable to engine/frame. I'd then hold the starter switch and aim the temp gun at the ring of said strap/cable, if not touch with said anal thermometer, or finger it for the 2nd degree fell of it. Take said meter, set to ohm and find ground [wire] on the key switch, and ground both frame/engine with the other meter probe. Set meter to 20-volts, with key on, ground probe(-) to frame, and probe each wire off the key switch to note voltage. With meter still set at 20v, probe (+) to the hot side of the battery, neg-probe to hot wire of starter relay.
    #15 Sven, May 7, 2019
  16. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Well I just turn it on, and pull the key out and put it in my pocket, no biggie.;)
    PROFLYER and bdm7250 like this.
  17. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    your spare keep that you didn't drop on the highway somewhere;)
  18. Mike Wilson
    northern ca.
    06 mastif
    willy
    I have a key switch on the way I'll let all know how it works. I'm ok with other people riding when my bike is ready to go. But when i'm broke it really bites .
  19. Mike Wilson
    northern ca.
    06 mastif
    willy
    Well The key switch wasn't the problem. Turn on the switch and wait five min and power comes on all by its self and
    bike runs fine. Turn off the bike and it may or may not power back up when the switch is turned back on. WTF
    Thanks for the suggestions though .
  20. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Have you check the EHC plugs?
