Daymaker install question?
Discussion in 'Ignition / Electronics / Batteries' started by Kobi, Aug 14, 2017.
  1. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback, 2004 CVO Deuce
    Kurt
    I am trying to replace my headlamp with the Daymaker many are buying thru Amazon. When I install the new assembly with the factory rubber seal/gasket, it will not allow the outer ring (chrome) to screw on deep enough to fit flush with the front edge of the headlamp bucket. Looking at the two assemblies, the Daymaker is about 1/8 thicker. My only option was to remove the rubber gasket and make a thin gasket out of heavy paper. I also noticed the Daymaker has a long wire plug on it and worried the factory wires would rub inside the housing, so I taped them up good to protect chaffing.
    What are you guys doing about the rubber gasket? Thanks, Guys
    Kurt
    bigkelk9 likes this.
  2. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    I asked the same question and everyone is getting rid of them, I just put mine back in the box with the factory light. Good choice!
    PROFLYER and BadDawg Bill like this.
  3. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    I had the same problem and I had to get rid of the rubber gasket also, there's just not enough room for them all to fit in there.
  4. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    I had some old thin o ring material laying around the garage that I cut a piece and glued the end together.
    Works good.
    :old2:
    Big D Florida likes this.
  5. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    The Daymaker is a sealed unit, so I just removed the rubber gaskets also.
    PROFLYER and Gmutoagrsv like this.
  6. Kobi
    Kobi Member
    Josephville MO
    Kurt
    Looks like the rubber gasket goes in the box with the old factory headlamp assembly. Thanks guys.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    That's what I did as well...no issues yet
  8. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    Like Mr. Wright said the unit is completely sealed. I can understand why they would use the gasket on the OEM headlight. But it doesn't seem like there is a need on the DayMaker. I left mine off as well.
  9. Big D Florida
    Troop Supporter Supporting Member
    While the lamp itself is sealed, the bucket is not. The seal will help prevent water from collecting inside the bucket where it can corrode it from the inside out.
    BWG56 likes this.
  10. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Oh. I didn't even think about that. Obviously I'm not the only person that left it out what would your suggestion be on how to secure the lamp with the gasket in place?
  11. Kobi
    Kobi Member
    Josephville MO
    Kurt
    I made a gasket out paper, heavy like from a file folder. I figured it would help prevent water from being driven past the bulb if caught in rain. Plus a small amount of cushion and barrier from metal on metal. There is a small hole next to the allen lock screw that should allow water drainage.
    Gmutoagrsv likes this.
  12. Th3InfamousI
    Texas
    Ideally you'd leave it in..but it's just the way it is. I'm not too worried about the bucket rusting I think the Chrome will be pitted before that.
    A homemade paper gasket wouldn't be a bad idea or you could grind down the backside of the LED bucket, it's plenty thick.
    My actual only concern about this LED is that nobody has to Fuck with the light anymore and when it's time to get in there the damn retaining ring will just be stuck lol
  13. Th3InfamousI
    Texas
    That's true there is also a drain!
