Creepy Clutch
Discussion in 'Transmission / Drive' started by Big Daddy 72, May 30, 2016.
  1. Big Daddy 72
    Full Member
    Bentonville, Ar.
    2006 Mastiff 2008 k9
    Big Daddy
    Got my mastiff all back together, adjusted clutch per spec. Got two issues though. When I pull the clutch all the way in bike still wants to creep forward like the clutch isn't fully engauged. But my other issue is the clutch doesn't start pulling/moving the bike until it's over half way out and doesn't fully lock up or engauge until the lever is fully released. Kinda puzzling..
    Am I missing the obvious?
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    What year is you're bike?
    chubs likes this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    And try backing off the push rod screw 1/8 or 1/16 turn instead of the 1/4 turn recommended
    Big D Florida, chubs and dentdude36 like this.
  4. Big Daddy 72
    Full Member
    Bentonville, Ar.
    Big Daddy
    It's a 2006.
    Got the cable bout perfect. Right there in the penny area.
    I have the rod set at 1/4 may be where the problem lies.
    The bike pulls slightly at idle. You can start it in gear but it drags on the starter a bit and gives a slight pull forward. It's easy to hold back/keep from creeping forward but you can tell something isn't allowing the clutch to fully engauge.
    Funny thing is the clutch used to start grabbing just as soon as you let it out. Didn't seem to pull at idle, but you could not get it in neutral at idle.
    Clutch looked good when I took the primary and basket all apart. I put the clutches and the steels all back in the same order they came out. So other than the rod I'm a bit puzzled.
    TapioK and chubs like this.
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :yesnod: try 1/16 -1/8 turn
    Big D Florida and chubs like this.
  6. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    Did the 1/16 to the 1/8 work?, did that fix the issue?
    chubs likes this.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Chances are if you have a 12 plate clutch system of you are still grabbing at idle with a 1/4 turn your clutch pack is below spec.
    The reason they went to 9 plates in the 08 and later big dogs was because the steels on the 12 plate wear too quick. Mine was out of spec in under 10k miles and made adjusting the clutch a pain in the ass. I replaced with a thicker Steel and got my pack to proper height and I'm back to a quarter turn and all is well.
    Measure your stack height needs to be 1.96"-1.98" if I remember correctly
    chubs likes this.
  8. Big Daddy 72
    Full Member
    Bentonville, Ar.
    Big Daddy
    I switched to Lucas automatic Trans fluid and never had a problem again.
    The hd synthetic primary fluid was causing it to drag and pull at idle. That's what I had to do to fix mine.
    chubs likes this.
