Compression Release failure
Discussion in 'Motor' started by BroadBand, Jun 25, 2010.
  1. BroadBand
    BroadBand Since late 60's
    NorthWest USA
    BD Chopper
    SS link for electric compression release
    Parts
    Replacement Parts
    l 90-4915 Release kit, compression
    l 90-4914 Release assembly, compression, electric
    l 50-7094 Washer, compression, 14mm
    l 55-1009 Cap, solenoid, silicone
    l 55-1010 Harness, wiring, compression, release
    l 55-1502 Connector, Deutsch, male - DTM06-2S-E004
    l 55-1503 Wedge, connector locking – Deutsch #WM-2S
    l 55-1504 Socket, Deutsch
    l 55-1508 Connector, Deutsch female – DTN04-2P-E004CH
    l 55-1509 Wedge, connector, locking- Deutsch #WM-2P
    l 50-0045 Kit, compression release, socket
    l 50-0046 Socket, compression release, bottom
    l 50-0047 Socket, compression release, top
    <LINK> for installation instructions
    :flag:
  2. copterguy
    copterguy Member
    Hawaii
    2007 Mastiff
    Loren
    ............ah, thanks very much. Just what I needed. I had already downloaded the instructions, but "Googled" the ELECTRIC COMPRESSION RELEASE 90-4914 part and voila! I love this forum..
  3. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Would these TP CRs fit our Dogs? $28 Only.
    [ame=http://www.amazon.com/TP-ENGINEERING-MANUAL-RELEASES-45-4020-21/dp/B000GTZAF0/ref=sr_1_sc_3?s=automotive&ie=UTF8&qid=1337052753&sr=1-3-spell]Amazon.com: TP ENGINEERING MANUAL COMP. RELEASES 45-4020-21: Automotive[/ame]
    Cheers,
  4. V
    V Guru
    Not sure but it would have to have the same thread pitch as the stock unit and you would not want it to protude any deeper than the stock unit. Also if you look at it, it is very short and would be very deep in the rocker box if it did fit. If you were to pull your heads they can be machined for C/R's right near the spark plug.
  5. francoblay1
    K9 (2006)
    Franco
    Would these fit the TP rocker boxes on the 06 K9???
    TP Engineering 45-4020-21 Manual Compression Release Valve
    with Billet Cap
    Manufactured from 303 stainless steel
    Available with billet aluminum cap or threaded to accept any standard tire valve cap for a truly custom appearance
    Require a .650" (1.65cm) 10mm x 1.0mm-threaded hole for installation
    Made in the U.S.A.
    TP Engineering ZZ 0950-0002 TP Engineering 45-4020-21 Manual Compression Release Valve with Cap For Harley-Davidson from BKRider.com
  6. Did these / will these work? I know....old thread.
  7. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    No. The above C/R's are 10mm. We have 14mm holes for our C/R's. Im researching this also as Im looking to replace the electric C/R's with manuals. But I dont like the cable operated manuals from S&S.
  8. francoblay1
    K9 (2006)
    Franco
    Bump.
    Has anyone found Manual CRs for our S&S heads?
    If/when mine fail I would like to go with Manual ones... (No Cable, just finger push!)
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Are you drinking again:confused:you can do that now, i slit the rubber and WD-40 them.
    francoblay1 likes this.
  10. Coolbreezin
    Northeast FL
    05 Ridgeback
    Pete
    I found these a while ago and have been sitting on them wondering if they would fit our heads. I wonder if S&S has a special thread cut so we are restricted to just their products. I know S&S wouldnt tell me anything, so I havent asked. I heard we have 14mm bolt holes so I wonder if these might work. Anyone with more info would be greatly appreciated here.
    Compression Release for Rev Tech Motors Harley | eBay
  11. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
  12. Diesel Dan
    Diesel Dan Active Member
    Sierra Nevada mountains.Extreme NORTH CALIFORNIA M
    2004 Big Dog RidgeBack 2006 Yamaha Raptor
    Danny
    x2 Brother Franco!!!!!!!!! BUT if the threads in the S&S Heads are as sensitive as John says,we might be stuck with the S&S Compression Release's.......I want manual ones also......
  13. BroadBand
    NorthWest USA
    BD Chopper
    I think I would trust John Sach's as the engine builder to know what works.
  14. francoblay1
    K9 (2006)
    Franco
    I bet there are some for the S&S..... I will make some inquiries! :up:
  15. Diesel Dan
    Danny
    Without a doubt,John's word is gospel with me:)....
  16. francoblay1
    K9 (2006)
    Franco
    John John.... John????
    Where are you????????
  17. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    Franco,
    Check your pm.
    The S&S manual or electric releases are the only game in town.
    John
  18. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    John,what is the machine in your avatar? What is the name brand?
  19. john sachs
    Deltona, Fl
    harleys
    SERDI valve, seat, and guide machine. Model 3.0 millennium.
    John
  20. KaptinAmerika
    2006 Big Dog K9
    Curtis
    If there are a few who need these I can put together a group buy.
