Compression Release failure
Discussion in 'Motor' started by BroadBand, Jun 25, 2010.
  1. BroadBand
    BroadBand Since late 60's
    NorthWest USA
    BD Chopper
    Over the weekend, during a 250 mile charity poker run, I had a compression release destroy itself. It's the first real thing that has gone wrong on my Big Dog and it did not leave me stranded. I have 13,500 miles on it when I was putting along at 75mph and heard a loud pop. From that point on, I could hear a new & different sound. Did not really notice a loss of power or anything.
    At the next stop, I looked down to see the rear jug CR laying in the hole with the silicone boot kitty wampas. Everything was out of whack big time.
    Called my mechanic and he said it would probably not hurt anything to finish the ride and since I was 150 miles from home, that was a relief.
    The bike started OK everytime I shut it down. You could definetly hear the "che - che" sound of escaping compression out the small hole in the CR.
    Upon tear down, some of the CR was no where to be found. It either melted of broke off between here and there...
    It takes a special tool to remove/install the CR's. I replaced both with brand new CR's at a cost of $365 approx. I needed the 2 CR's and 2 gaskets for the rockers. It's now running strong like always.
    What follows are pictures of the old parts so you can get an idea of what the CR's look like incase you never have had all the fun this trip turned out to be.
    :flag:
    Big D Florida likes this.
  2. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    Nice write up.
    Where did you buy the tool to remove them and how much did it cost?
  3. Eric
    Eric Banned
    griffin ga
    mine did the same thing with less than 3K on it.. rear cyl... it was under warrenty though...
  4. BroadBand
    NorthWest USA
    BD Chopper
    Compression release tool
    The S&S tool is around $80.00 and is pictured HERE
    :flag:
  5. alphadog
    alphadog Active Member
    Welcome to New Jersey..Now go home!
    Harley Davidson Ultra Limited FLHTK 2014
    Jerry
    Thanks for the info. Good to know. I would be curious to see how many others fail and at what mileage so we can replace em before they blow.
  6. Big Bruno
    Big Bruno New Member
    Harley Davidson
    What can I use to loosen a sticky CR? When I start, I have to crack the throttle. Front cylinder.
  7. Eric
    Eric Banned
    griffin ga
    I now have had to replace the frt cyl.to.. about 300 miles after the rear (rear relpaces right before warrenty went out) I bought the S&S comp.release tool & I got 2 comp releases ,replaced the frt & got a spare now.. now that I got 2 bdm with em I figured I had better invest in em & keep @ least 1 on hand.. not a difficult job .. the dam rubber cap is more difficult than the comp release..
  8. Nomad2day
    Nomad2day Longhair Redneck Geek
    Clarksville TN
    Gone but not forgotten 07 Bulldog, Now a 1966 Harley Davidson FL Electra Glide
    Neil
    You can manually press it down before you start it.
    Carbon builds up on them as well and makes them stick as well. Just pull the rubber boot off and use some good penetrating oil on it and press on it until it loosens and springs up on it's own. I use Kroil penetrating oil myself.
    Been there and done this already. I also have the S&S tool as well.
    Neil
  9. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    I want to pull the compression release valves out and check for maintenance. Can I use a deep well 12pt socket to remove them?
    WHAT SIZE SOCKET?......12point, 1", 3/8" drive or what? 2-3/4" clear deep bore I've read on other another post.
    If a deep well socket will work I'll cut a hole in the side of it to allow the CR cable to exit out. Or cut out an extension corner.
    Do you need to pull the rocker covers off to get access to the CR for removal?
    Thanks
    #9 BigDogBro1, Dec 17, 2010
  10. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    :up:
    NO,NO, NO.............
    Pull rockerbox top,and sometimes you need to remove the rocker arm saddle.
    Use only the S&S tool.The threads are VERY fragile. :bang:
    Do the job the right way. :up:
    John
  11. billyberoux
    billyberoux Member
    2004 chopper
    Mine were always failing on my 04 big dog chopper so I pulled them out and plugged them up wth bolts and I've never had a problem starting the bike. The tool costs $60 but most shops will loan it to you so long as you put a deposit down.
  12. BigDogBro1
    Near Hell MI
  13. BroadBand
    NorthWest USA
    BD Chopper
    Hard to argue with that!!
    :flag:
  14. uberhawg
    uberhawg New Member
    N Plainfield NJ
    BMW R60/5
    Excellent writeup. S&S doesn't let them show the price online but Retrocycle has that tool for $80.99 if you want one.
  15. Tom Chop
    Tom Chop Active Member
    Cottondale, Alabama
    `06 K-9
    Tom aka Tom Chop
    Thanks To Neil In Tennessee
    Nomad2day I appreciate the info on how to clean and lube the compression releases on our beloved "Dogs". I further agree that Krull Oil and lube would be best candidate for breaking down the carbon and lubing the "CR`s". Thank You Nomad2day and all contributers for the great tips. As usual here on the forum you all rock. :flag: :cheers: :2thumbs: :roll:
    Thank You All
    Be Kind
    Take Care
    Tom Chop
  16. TCALZ06
    Chandler, AZ
    07 Big Dog K9
    Tom
    Looks like I have a rear compression release not working.
    Where are you guys buying these at? I see the kits but I only need one.
    thanks
  17. HotWheelz
    HotWheelz Member
    2008 BigDog Ridgeback
    What about just installing a set of manual Compression releases. My buddy had to install them on his 10.5/1 96 cu Harley.Why do it electronically?
  18. V
    V Guru
    Just replace my rear one on friday. Got it from Lena At Strokers
  19. V
    V Guru
    S&S has a manual set that has a cable that goes to both of them. I don't really like the looks of that set up. There are a couple of others out there wtih the 14mm thread that look like they would fit and you just push down on the top of them. If they would work that would be my choice.
    Then theres also having the head machined and thread for the 10mm ones.
    Anybody runnin the manual releases?
  20. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    Well it seems like a big expense when they fail. What harm to just plug them up and get rid of them?
