Cleaning the 08 efi throttle body.
Discussion in 'EFI Topics' started by chili08k9, Aug 11, 2017.
  1. chili08k9
    chili08k9 I will buy the 1st round
    Jamestown NC
    2008 Big Dog K-9 (EFI)
    Mike
    Sorry i dont get on here much anymore, but I now have a new dedication to the ol pup. I searched but cant find any video or info on how to remove clean and what to clean with, and reinstall the Throttle Body on my o8 K9..any help will be greatly appreciated. mike
    USNChief likes this.
  2. USNChief
    USNChief Active Member
    Middleburg
    2008 EFI Mastiff
    Steve
    Sorry can't help Mike, had almost every other problem with 08 EFI, but throttle body ain't one of 'em. Knock wood.
    chili08k9 likes this.
  3. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    Strip the T-body of all its removable parts. Use " Brake Kleen" or an equivalent spray solution. Clean inside of t-body. You can take the injector nozzles to a car shop who has the means to clean them, or you can make a setup to handle that.(Prolly won't pay unless you're going to go into business in that area). Check fuel pump pressure. Reinstall parts, and you should be good to go.
    Don't forget new seals throttle body to heads.
    John
  4. john sachs
    Deltona, Fl
    harleys
    Many times I find an oily mess coating the inside of the throttle body.
    Look in your throttle body, and if it's clean, skip that part of it.
    John
    Big D Florida and chili08k9 like this.
  5. john sachs
    Deltona, Fl
    harleys
    You may want to check your Street Glide also. Especially with the shitty Harley breather system.:oops:
    John
  6. USNChief
    Middleburg
    2008 EFI Mastiff
    Steve
    Thanks John.
  7. chili08k9
    Jamestown NC
    Mike
    was cleaning the K&N air filter, twisted the throttle and inside the T/B behind the butterfly it is so oily black, guess i have never noticed that before I bought so me good throttle body cleaner and will do it tomorrow while its raining.... (never had any issue with it though...) thanks guys
    john sachs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Oh brother, hope it don't turn out like the tranny plug, too soon:sorry: :oldconfused: no I ain't :oldlaugh:
  9. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    When you take your throttle body out or don't. Remove the IAC stepper motor and clean that area also. There is a small hole that runs from the stepper motor housing diagonally back into the throttle body. Clean it with a Q-tip and some brake clean. Be care full not to clean the map sensor or the IAT sensor with brake clean.
  10. BWG56
    BWG56 Guru
    Big Dog
    Ker
    You have that Kabota dealer right by you, drive the tractor out there and pick up a new one and tell Dale you got it back together and gave it a paint job. :D
    My garden isn't that big so I just turn the soil over with the BH, :old2:
  11. BWG56
    BWG56 Guru
    Big Dog
    Ker
    K&N's are the way to go:old2: I have them in everything I own that they make them for.
    Big D Florida likes this.
  12. Big D Florida
    Troop Supporter Supporting Member
    Do the EFI bikes have that crankcase breather running to them like the carbed models? If so, rerouting to a puke can or check valve down low, and plugging the port where it attaches to the TB, like we do with the carbs might help it stay cleaner..
    Just a thought.
