Checking primary and changing oil
Discussion in 'How-To' started by EJ, Jun 19, 2008.
Thread Status:
  1. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Ok Start out by draining the old fluid, located under the primary.
  2. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Then remove the inspection cover to make sure most of the oil is drained.
  3. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now remove the bolts around the primary cover and watch for any remaining oil.
  4. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now that the cover is off you can look over the sprockets, chain, clutches, and tensioner. Made sure all nuts and bolts were tight.
    #4 EJ, Jun 19, 2008
  5. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Check your tensioner and make sure it is not loose or the teflon is wore out. If you have to tighten dont overtighten. Should have some deflection.
  6. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    No excessive ware on mine looks ok.
  7. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now I checked my sprockets and the teeth for excessive ware or chips all looks good.
  8. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now I checked the cain and it lookes good no rollers missing or anything else.
  9. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Inspect the gasket and wipe out old oil to remove shavings from cover and inner primary.
  10. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now reinstall the cover making sure the gasket is not piched then
  11. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now reinstall the drain plug with pipe dope or your choice of sealants
  12. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    [​IMG][/IMG]
    Now fill with your choice of oil and reinstall the inspection cover and check for leaks.
    wuudogg likes this.
  13. bdmridgeback
    bdmridgeback Low Down Chop Shop
    SW FL
    '05 Ridgeback
    Jake
    Great How to for the Guys that wouldn't normally take on that job! Shows how easy it really is! :2thumbs:
  14. 05chop
    05chop Well-Known Member
    wyoming
    05 DT Chopper & 2010 Street Glide
    Whats that big ding in this picture that you posted above the front sprocket nut ?? your post said----Now I checked the cain and it lookes good no rollers missing or anything else.
  15. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    Good Job :2thumbs:
  16. T Mack
    T Mack SUCKER FREE
    DetRiot, MichiGun
    2006 Mastiff
    Dick
    Good Job...
    :2thumbs:
  17. EJ
    EJ Member
    lancaster, sc
    2002 bulldog
    Well I think that there was three dings in it and it looked like it may have of been a crimp or something like it. If im wrong someone let me know.
  18. Chopper Dave
    Chopper Dave SIICK!!!
    Michigan
    2011 Ultra Limited
    Dave
    good job E J :cheers: :up:
  19. KDF
    KDF Active Member
    Groveland, MA (35 Mi. N. of Boston)
    '06 Pitbull, '01 Fat Boy
    Ken
    Do you need to replace the primary gasket with a new one or can you reuse the old one...?
    KDF
  20. dogvet
    dogvet Banned
    the shitty side of the rainbow
    custom
    the dings are indeed crimps that hold the compensator springs in the shell.
Thread Status:
