Changing oil
Discussion in 'Motor' started by Deathstar88, Mar 20, 2016.
  1. Deathstar88
    Deathstar88 Active Member
    Poconos , PA
    2003 Pitbull
    Are there any videos online or on this forum that demonstrate how to change engine oil on a S&S 107? I see the drain plug under the engine, but I cannot find the drainline from the oil tank. I see a black line coming out with a round bolt in it. not a allen. can I just remove the drain plug under the engine and drain the oil that way? Step by step instructions would be great. The tranny seems easy enough. just a little confused about the engine
    chubs likes this.
  2. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    I believe your drain plug should be at the rear of your oil tank, have you looked there? I'm with dent, your not going to get a lot of oil out of your case drain.
  3. Deathstar88
    Poconos , PA
    2003 Pitbull
    yes...I see a black line that comes down from under the seat, but that line is capped off with some kind of flat looking bolt.
    chubs likes this.
  4. Brew
    Washington State
    Rob
    That should be the oil tank drain line. There use to be pics of it on here, but I think the pics dropped off when the site was improved.
    dentdude36 and chubs like this.
  5. Bowhunter
    Bowhunter Well-Known Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    You might find this helpful. It is not your bike, but similar. DO NOT pull that plug from the bottom of the engine.
    cdogg556, chubs and dentdude36 like this.
  6. heybaylor
    heybaylor Active Member
    Full Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    pull the round plug from the line , aim it into the bucket
    do not pull the plug on the bottom of engine case:cheers:
  7. Deathstar88
    Poconos , PA
    2003 Pitbull
    the black drain line is locked on to the frame on a curve. I pull the round plug off with my bare hands? where do I fill the new oil? under the seat? sorry for the dumb questions, this is my first time attempting this
    chubs likes this.
  8. Deathstar88
    Poconos , PA
    2003 Pitbull
    that video you posted actually says to drain the engine plug to remove a resovoir of dirty oil. my drain line from the oil pain does NOT have a allen hole. Its just plugged with some kind of round rivet type thing. no way to unscrew it. very odd
    chubs likes this.
  9. Brew
    Washington State
    Rob
    Should be under your seat according to the owners manual. You tank holds approx 2 1/2 qts...
    Bike needs to be straight up and level and the oil should be 1.5 inches down from the bung...
    chubs likes this.
  10. Bowhunter
    Oliver Springs, Tn.
    2009 K9
    Steve
    On my '99 Bulldog, there was a black rubber hose that came down from the oil tank for draining the oil. It was plugged with a billet aluminum plug which is retained with a clamp. The hose was then zip-tied to the swing arm. If your bike is like my '99, you will find the hose zip-tied to the frame or swing arm and removing the clamp and billet plug will drain the oil tank. Your fill neck and dip stick will be under the seat I believe.
    After you drain the oil, you remove the oil filter and then the oil screen near the pushrods to clean it before you replace the filter and the oil.
    heybaylor and chubs like this.
  11. Deathstar88
    Poconos , PA
    2003 Pitbull
    Awesome. Thanks. How did u pull the billet plug out of the drain tube? And I noticed my crank case breather filter is dirty. Can I clean that? Or should I just buy a new one?
    chubs likes this.
  12. francoblay1
    francoblay1 The Spaniard
    Full Member
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Don´t you have the 2003 Service Manual???? :here:
    BWG56 and chubs like this.
  13. Deathstar88
    Poconos , PA
    2003 Pitbull
    No franco. I don't have the manual. I'd love to have one
    chubs likes this.
  14. francoblay1
    Full Member
    K9 (2006)
    Franco
    Click this LINK :old2:
    :chopper:
    xxcarpxx, BWG56 and chubs like this.
  15. Deathstar88
    Poconos , PA
    2003 Pitbull
    I read through it. I understand what I need to do now. Now im wondering if I should replace my 13year old crank case breather/filter. Its filthy.
    chubs likes this.
  16. SKOGDOG
    SKOGDOG One of the old ones.
    Supporting Member Full Member
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    You should be able to clean it with a can of brake cleaner spray. I have used the same ones for a long time and all I do is take it off and spray it inside and out with brake cleaner and blast it with air (optional), and put it back on...good to go---maybe not for another 13 years, tho....:eek:
    chubs likes this.
  17. Deathstar88
    Poconos , PA
    2003 Pitbull
    Im better off just buying a new one. they are cheap enough., This is a NO Return crankcase breather filter, right? any specific size? or are they all a universal fit?
    chubs likes this.
  18. SKOGDOG
    Pittsburg, Kansas
    Rick
    Some guys just run the tube straight down with no filter at all. It catches oil and hopefully keeps it from dripping.
    The short answer is use whatever you want.
    Mine will pump out some oil if I don't keep a dry filter on it to soak it up. Gets messy at 80+ mph on 600 mile days.
    chubs likes this.
  19. Deathstar88
    Poconos , PA
    2003 Pitbull
    jp cyles has one that says it connects to 5/16 hose., and amazon has one that says 3/8. how do I know what is the correct one? are they all a universal fit?
    chubs likes this.
  20. Deathstar88
    Poconos , PA
    2003 Pitbull
    What is the K&N part number for my 107? K&N 170 fits all S&S motors?
    chubs likes this.
