Changing headlight bulb
Discussion in 'General' started by onaprwl, Feb 27, 2018.
  1. onaprwl
    onaprwl Onaprwl
    Covington, Louisiana
    Big Dog K-9
    AL
    Could someone please tell me if the ring that holds the headlight is counter clockwise or clockwise to remove before I get pissed and throw the whole headlight away and buy a new one for no reason!
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Righty tighty, lefty loosey
    SCOTTx88 and dentdude36 like this.
  3. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 2003 Pitbull, 2006 Mastiff
    And there you go!
    dentdude36 and BWG56 like this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldhardlaugh::oldhardlaugh:
  5. onaprwl
    onaprwl Onaprwl
    Big Dog K-9
    AL
    Thanks guys. Let me go try this again and see if the light ring gives before my patience!
  6. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    Throw some rubber gloves on. Makes it easier to grip.
    Nice to see the older members still helping out when needed :oldthumbsup:
    If you stand behind the light and reach in with your fingers it will give you more leverage..
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You can try rubber gloves for grip on the outter ring, and 2 punches in the grooves for the retaining ring.
    SCOTTx88 likes this.
  8. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Unless he's got an Adjure bucket..
  9. pknowles
    virginia
    paul
    Then he can use the hammer:)
    SCOTTx88 and bdm7250 like this.
  10. bdm7250
    bdm7250 Guru
    Doug
    :skep:
  11. pknowles
    virginia
    paul
    I didnt say big hammer or a chisel :oops:
    bdm7250 likes this.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    To bad others don't step up:oldbang:
  13. pknowles
    virginia
    paul
    I do what i can with my limited ability.
  14. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    All respects onaprowl, but did you remove the tiny Allen set screw under the 6:00 position?
    I sprayed mine with a bit of penetrating oil, then cleaned up the ring and used rubber gloves as mentioned above. I also gently tapped around the outside of the ring with a plastic hammer hoping to help the oil penetrate the threads.
    If you can get the thing to move a millimeter, you'll win. In fact, as I recall it was the next day when that ring finally moved.
    bdm7250 likes this.
  15. MossBerg590
    MossBerg590 Active Member
    Arizona
    06 Big Dog Ridgeback
    Tyler
    Good luck, it can be a pain in the ass. If your like me, save the whiskey until after you get it off..I got pissed off and ended up drilling a small hole through the set screw hole so I could get the edge of a punch on the ring and tap it loose. Worked but I'l need to pick up a new ring someday
  16. Angusfarmer
    Angusfarmer Member
    Winchester, tn
    2005 pitbull. 1960 harley servi car
    Zac
    That's basically what I did with mine to. I didn't mind having to replace a ring, but it bothered me not being able to ride due to a burnt out headlight.
  17. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I've stripped out the allens on both K-9s I've owned -- these days my beauty ring is held in place after its screwed in with a really small dab of clear silicon on the top underside of the bucket where you can't see it.
    Hit it with a knife, use the gloves and comes right off.
    Whoever decided to use a stupid small allen set screw is on my list!
    pknowles likes this.
  18. 1badridgeback117
    Hardy, Kentucky
    2004 Big Dog Ridgeback
    Tommy
    I stripped my Allen screw out today when i installed my daymaker headlight on my Ridgeback. They are wicked easy to strip.
