SimpleMan_Omen
I have put the rear wheel back on. I got it together and adjusted enough that there was proper tension on the belt and the wheel was spinning parallel to the belt then noticed that it was scrubbing on the right side inside the fender (against a screw).
Looking at it I'm not sure how to get the rear wheel centered in the fender.
You can see here that it is shifted a little to the right.
Plenty of gap on the left side between fender and tire.
Very close on this side and touching further in where the picture doesn't show.
Right side of the bike. Small spacer inside with the lip against the bearing and the medium spacer outside between the frame and rear brake bracket.
Left side. Large spacer installed with lip against the bearing.
The bike is a 2003 Pitbull. If anyone has an idea let me know. Or if you have a 2003 Pitbull I would love to have pictures of yours.
