Cams... 585 vs. 600 vs Other
Discussion in 'Performance' started by zenBD, Nov 5, 2014.
  1. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    08 K9 & 2015 Ducati Diavel
    Matt
    So... I finally (shouldn't say this/knock-on-wood) got my bike to a point where I'm not having any issues, so (naturally) now I have to change something. :whoop:
    I really want some more power, but I don't want to go crazy just yet, so I'm thinking cam. I have been reading a lot of good stuff about the .585... seems like what the Dr. ordered. Anyone have any experience with both the .585 and the .600 or those vs. a non-S&S cam like a Crane or Headquarters... any notes on how they compare?
    Really looking for more torque, but also just a better curve as well.
    I'm running the super G, VH 2-2... otherwise stock. I do have the upgraded Thunderheart ignition sitting in a box which I'll install when I do the cam.
    I'm really curious if anyone has tried multiple cams and has settled on one they like the most.
    Thanks for the input :2thumbs:
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I have the .585 in mine but I don't think the TH ignition adds anything, but you will feel the difference with the cam. Matter of fact I am going to remove the TH and go back to the stock ignition. If your a Joe race kinda guy, maybe the TH could make a slight difference, but for my style riding I didn't see it.
    Bdm4ever likes this.
  3. francoblay1
    francoblay1 The Spaniard
    Full Member
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    I do agree with Ker on the cam. The 585 has lots of Torque & goes Up on revs very Nice & Fast :2thumbs:
    But... I do not agree with Ker on the Ignition... I did feel the difference... I do like the TH Programmable Ignition: you just need to play with the settings depending on what Altitude (Sea Level) you are, and make sure your Carb is well regulated.
    1. http://www.bigdogbiker.com/forums/performance/52003-new-mods-success.html
    2. http://www.bigdogbiker.com/forums/general/61510-i-am-back-road.html
    Ker, why would you go back to stock on the IM?
  4. francoblay1
    Full Member
    K9 (2006)
    Franco
    Adding to my last post...
    If you want to go with the 600 cam, then yes you need more work (cut jugs = more compression) etc. plenty discussions on the subject here in the Forum.
    If you want just more (overall) Torque & a few more Ponies, just go with an easy Cam swap (Plug & Play) .585 Cam. :2thumbs:
    http://www.bigdogbiker.com/forums/how/27075-585-cam-install-09-k9.html
  5. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    Matt
    Thanks, Franco... sounds like just what I'm looking for
    francoblay1 likes this.
  6. francoblay1
    Full Member
    K9 (2006)
    Franco
    Just Do It! :2thumbs:
    ... and keep us posted.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    For those that are not familiar with the S&S IST ignition, it automatically creates a custom timing curve for your motor. This is based on the addition of an Intake Manifold Absolute Pressure (MAP) Sensor, cylinder temperature sensor, knock (ping) sensor and replacement crank sensor. It can change your timing from 26-50 degrees per my tech but will only advance as far as the knock sensor allows. This should give you better performance and mileage. Another nice feature is that if you are stuck someplace where you cannot get premium fuel it will adjust your timing curve to compensate. What it cannot do is adjust your air/fuel ratio. So if your jetting is not right it may try to adjust itself into some kind of a performance reducing mode.
    Another benefit is an improvement in MPG. Used to get about 26-28 mpg but after running a full tank through it I'm up to 39 mpg.
    Franco,
    This was copied from another post and my mpg went from 45 to 28-30 after putting in the TH. I just don't feel any difference with my style of riding, and the above mentioned as far as advancing or retarding the timing upon engine conditions is more important to me.:whoop:
  8. francoblay1
    Full Member
    K9 (2006)
    Franco
    Interesting for sure.... I don´t know my mpg... but I do know its shite.... I burn a full tank in a couple hours. I will e-mail you. :up:
  9. desertdawg
    desertdawg Member
    Full Member
    Tucson, Az.
    2008 EFI K-9 / 2006 CARB Mastiff
    Ron & Sharon
    If you talk with s & s 585 then ride I like you stole it!
  10. FLCRO
    FLCRO Member
    Full Member
    Cocoa Beach, FL
    '07 Chopper
    Chad
    I've got the .600, but did the necessary jug work. You will feel it, for sure. Huge difference.
    I'd suggest the .585 though. A lot less hassle then taking the top end apart.
  11. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    Matt
    Thanks guys.., looks like the .585 for now... Save the .600 for later
  12. flcmcya
    flcmcya Active Member
    Full Member
    Twin Cities
    2005 Bulldog 2007 K9 LE
    I recommend trying the ignition before you do the cam swap, you may like it as is.
    I was very surprised how much more grunt was there , I was running a Triple x Carb and some better pipes.
    I did throw the 585 in later though! :bang:
  13. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    Matt
    What setting did you run the ignition on before the cam? Did you change the setting after the cam?
  14. francoblay1
    Full Member
    K9 (2006)
    Franco
  15. flcmcya
    Full Member
    Twin Cities
    I ran it on setting 2 and it really bumped up the bottom end!
    I'm running #3 with the 585.
  16. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    Matt
    Has anyone running the .585 felt like they suffered any reliability issues or caused any damage due to the swap?
  17. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    I've had no issues here and like most installed programable ignition along with the cam...
  18. francoblay1
    Full Member
    K9 (2006)
    Franco
    Yup, same here with nil issues :2thumbs:
  19. zenBD
    zenBD Active Member
    Full Member
    Deland, Fl 32724
    Matt
    Thanks guys
  20. francoblay1
    Full Member
    K9 (2006)
    Franco
    So..... how is it????? :oldsmile:
    BWG56 likes this.
