Cam change revisited.
Discussion in 'Motor' started by Oldskuul, Mar 15, 2011.
  1. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    And if anybody wants one, you can have mine! It's the same that V just listed. :cheers:
  2. Oldskuul
    Oldskuul Member
    Full Member
    South Florida
    I just ran my K 9 today with the stock cam. It's very quiet, doesn't pull like it did.
    On the bright side it does idle through traffic nice and smooth, the bucking is gone at idle speeds, and the power has shifted down noticeably from 3k to the 1500 range.
    I'll be looking at the 585, woods and Jackie cans now.
  3. stryfox
    stryfox Active Member
    2008 Big Dog Mutt. custom suzuki intruder
    I put the 585 in my 08. It runs good. It feels the same putting around but has more noticeable torque on comand.
    I have not dynoed since the change but plan on doing so this spring.
  4. Nomad2day
    Nomad2day Longhair Redneck Geek
    Clarksville TN
    Gone but not forgotten 07 Bulldog, Now a 1966 Harley Davidson FL Electra Glide
    Neil
    I run a 656V2 Red Shift cam in my 2007 Bulldog, EFI and absolutely love it. Makes 131tq at 1500-1800 rpms and is a torque monster all the way through.
    I do run a Thundermax wide band system instead of the S&S VFI and I did modify the compression to fit the cam. John Sach's did my head work/valves and milled the heads for everything to work together and it has been a great package to include the exhaust..
    It is not jerky and pulls hard in any gear at any rpm or is as passive as you want it to be. Fuel mileage is dependent on where I want my AFR set to...Cruise, brute power or anything between.
    Set your bike up for all the components to work together and enjoy it..
    Neil
    john sachs likes this.
  5. BadBrad
    Brad
    That sounds bad ass Neil! That's what I'm talkin' about. Not looking for quiet. I like a little snap, crackle and pop on decel and blue fire jumping out the exhaust at night. I'd be a little disappointed if it didn't do all that. :cheers:
  6. DoubleD
    DoubleD Active Member
    Jonesboro, Arkansas
    2008 Ridgeback
    David
    I'm considering changing my cam. Do I have to buy a kit or can you just change the cam?
  7. stryfox
    Cam and gasket. Shims may be nessasary.
  8. DoubleD
    Jonesboro, Arkansas
    2008 Ridgeback
    David
    Thanks, Thats what I thought. I called Stroker and they wanted to sell me kit that was over 700.00.
  9. echoniner111
    echoniner111 Active Member
    Yadkinville , NC
    2005 big dog ridgeback
    Chad
    I priced a 600 cam install today by kendall johnson customs for 480.00 buks. That's for the purchase of the cam also. Someone said this was a easy change out, how true is this and whata you think about the price
    S&S cam with all tha shims and a quart of oil.
    #29 echoniner111, Mar 22, 2011
  10. Oldskuul
    Oldskuul Member
    Full Member
    South Florida
    The cam change is deceptively simple. Pulling the can tower off to measure for the shim (didn't even need to change it) was the hardest part.
    Fwi if I get motivated my 600 cam will be heading to ebay soon.
    Some one asked why I switched back to the stock can when I know that I will be replacing it again soon, well it really is a simple change..a nice way to spend the morning I'd say.
  11. PaulHart
    PaulHart Well-Known Member
    Oklahoma
    2009 Mastiff
    Paul
    When you get that 585 in I'd like to see some numbers if you dyno it.
  12. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
  13. stryfox
    If you read the cam threads here.
    Make sure if you go with the 600 or bigger you make sure your springs are rated for it.
    Some years are fine sone are not.
    I went with the 585 and needed no new springs on my 08
    It was a simple job. The longest part was driving to the hd dealer to pickup a gasket I forgot to order. It took longer to adjust the push rods then to install the cam.
  14. Flares
    Flares Member
    FL Panhandle
    '07 Big Dog Mastiff, '00 Harley Davidson FXDX, '78 Honda TL-250
    Appreciate all the comments... :up:
    I'm out on the road and had Carls Speed Shop install Carls grind CM580 yesterday... 1st riding impression is great, a noticeable boost in mid range torque up 4500-5000 rpm. I already had the VH 2 into 1 Big Radius pipe and 31/76 jets. I will get back here in a few weeks and more miles with the new setup. I'll get a decent idea of highway performance on my ride home to the FL panhandle.
    Brett. :flag:
  15. toadstool
    toadstool Active Member
    Ohio
    2008 Mutt, 2004 ZX10R
    Jesse
    If you are going to do it, might as well do it right, Woods .650 all the way.
  16. 117 cu in
    117 cu in Member
    PA
    2011 Ultra Limited...2007 117 Cu in custom
    With the 117 motor why hasn't anyone mentioned the 640 cam ? It will require some head work and stronger springs. Mine has 11.1-1 compression and runs great !!
  17. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
  18. bdm7250
    bdm7250 Guru
    Supporting Member Full Member
    Hamilton Ontario Canada
    Doug
    I know with the Woods 630, it runs great at low speeds...after all, I've ridden with you.:oldlaugh: :moped:
    dentdude36 likes this.
  19. bdm7250
    bdm7250 Guru
    Doug
    What the hell do you care, your top speed is 37...:moped:
    BWG56 and dentdude36 like this.
  20. bdm7250
    bdm7250 Guru
    Doug
    Good idear.. :oldlaugh:
