Busted it good!
Discussion in 'Transmission / Drive' started by SKOGDOG, May 25, 2016.
  1. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    Eric,
    does the inner hub for the baker fit on the bandit basket and vice versa? And let us know if you find out anything on the pricing.....
    chubs and SKOGDOG like this.
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    it was enough of a problem for BDM to do a service bulletin on it.
  3. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
    That's enough for me, since I'm planning on doing some longer rides, I don't need any known issues kicking my teeth in.
    Bdm4ever, chubs and Marky-Marc like this.
  4. liferider
    liferider Guru
    Louisiana
    Jonathan
    Replaced mine when I went with the dry lock up clutch
    chubs likes this.
  5. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    not trying to scare, just saying to be aware of it, i have 17k and no problems (yet). but when i change my primary fluid, i take the outer primary cover off and look for shavings/ chunks.
  6. Wills67
    Wills67 Well-Known Member
    Texas Motor Speedway
    2004 Mastiff
    Mike
    Is this on all years? Or only on RSD?
    chubs likes this.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Just RSD 05+ that run the baker primary. I think even 08 has the bad cast carrier, maybe fixed in the 2011 models?
    chubs likes this.
  8. Th3InfamousI
    Texas
    Okay folks just got a call back from Bandit. Here is the full on scoop, I talked to him for a bit and asked if they are still selling like they used to and he said "They are still breaking, not as much as in the hey day but"
    Anyways,
    You can buy just the Carrier for $112 which works with the Baker Inner Hub and Bearing assembly. For $140 They will ship you the Carrier and new Bearing as mine as well replace the bearing if your pressing out the hub out of the stock carrier you'll probably trash it anyways.
    They are still selling the Bandit Bruiser Setup for about $400 which comes with everything except the INNER HUB which you have to use your stock one, or for about $500 you can buy the WHOLE Bandit Clutch/plates/hubs and all just drop it in.
    I ordered a new carrier while I was on the phone with him mine is fine but next time I have the primary off I'll swap it out, almost sprung for the whole setup. But new carrier & bearing from bandit and an inner hub from Curtis will get you all going for about $265 which is the route I am going to take. I think the Inner Hub has to be pressed in, can anyone confirm this?
    Oh and they are in stock - Mine is being shipped out today.
    #28 Th3InfamousI, May 26, 2016
    chubs, SKOGDOG and Marky-Marc like this.
  9. Marky-Marc
    Des Moines, IA
    Marc
    Wow! Thanks for the info Eric!!!Killer deal!
    chubs likes this.
  10. Th3InfamousI
    Texas
    Yes, in my opinion if your gonna spend $400 for a baker carrier just buy the whole damn clutch assembly for $500 comes pre-assembled.
    Now if you want to go cheaper, you can go my route. I don't have the 5 bones at the moment to drop on it...but maybe i will later and sell this carrier
  11. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Yes the inner hub is pressed in.
    chubs likes this.
  12. Th3InfamousI
    Texas
    Sweet thought so...perfect excuse to buy the Press! I only need one excuse to buy a tool!
    chubs likes this.
  13. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Thanks for the work on this one, Eric...you are the man! I already have the Dog reassembled and changed oil, or I would go that route too. If it breaks, I'll follow your lead. It sounds like a very adequate setup, especially for a stock engine , or one with mild improvements like mine (585 cam, decked, V&H, etc.). The stock clutch holds my engine just fine, and I am not too rough on clutches, either.
    All set to leave for Chicago in a week or so, and then of course Sturgis. I have to work in July! Dammit....on a short leash for a month.
    chubs likes this.
  14. Th3InfamousI
    Texas
    Just got the new carrier and bearing in from bandit.
    I have a feeling this boy ain't breaking! Damn thing weighs 2.14lbs
    Cost was $158 with shipping.
    Twisted, BWG56 and chubs like this.
  15. Twisted
    Twisted Well-Known Member
    Hazlet, New Jersey USA
    2005 Big Dog Chopper
    Butch
    Glad I saw this, I just took mine apart today to find the same thing, a broken carrier, and started searching for a new one so I can get the dog back on the road. Big question is, anyone know how difficult it is to press out the old inner hub and press it in a new carrier? Everything seems to look good on my setup besides the cracked carrier, 12 clutch plates look good as far as I can tell and the rest of the clutch housing looks good but pulling this apart is the first time I've even dug into a bike primary/ clutch. So need to decide if I want to go the same route as Eric or just buy the whole setup.
    20160617_195115_resized.jpg 20160618_133710_1466277286167_resized.jpg 20160618_133728_1466277267025_resized.jpg 20160618_133753_1466277288144_resized.jpg
  16. Th3InfamousI
    Texas
    Your gonna want a new hub regardless. That one you have isn't heat treated baker has an updated one.
    Up to you either buy a whole bandit setup for just under $500
    Or buy the bandit carrier and hub from baker which cost about $300 after shipping.
    If you got the extra 2bones go bandit
    Twisted likes this.
  17. Twisted
    Butch
    So the stock hub was shit too? I thought I saw that Curtis said Baker no longer sells just the hub you have to buy the whole setup for $400
  18. Th3InfamousI
    Texas
    Nope Curtis sells the hub alone for $125. Call baker direct monday since Curtis is tied up they should sell you just the hub. Heat treated
    Baker won't sell just the Carrier gotta buy hub too and they want $400. Go bandit route saves $125
    Twisted likes this.
  19. Twisted
    Butch
    Ok thanks, I'll give it a try. Yeah I know Curtis is out of service till mid July with the move.
  20. Twisted
    Butch
    Hey Eric, when you talked to Bandit you say the entire unit is $500? Im guessing that you still reuse the outer chain sprocket with starter ring? Do you know if that includes the inner hub and the carrier? If so did you ask if they would sell a carrier with the bearing and inner hub assembled to use with the rest of the stock parts. Sorry to bug but hate how no one is open weekends.
    BWG56 likes this.
