Brakes Lever Pulls Flat
Discussion in 'Brakes / Suspension' started by Satterfield, Apr 30, 2017.
  1. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    Hey, rebuilding the master is duck soup even Kevin can do it.... Changing a line is simple too if you have the vacuum bleeder. Why not try it and maybe you will surprise yourself and get more confidence and know your dog better... You can still ride with just a rear brake just take it easy..... I rode a chopper for years without a front brake... and a custom for a year without a back brake...
  2. Satterfield
    Satterfield Member
    Tampa, Fla
    08' Big Dog K-9
    Tony or "T"
    Bill, you make me want to try it. However, I have a lousy track record when it comes to fixing things in general. I might give it a try..I always wind up losing something or breaking it. I hate not being able to do it myself, so your right I should give it a try but it sounds like it will be any number of things. Even with the Master, if its not leaking, which it never has before, I don't see where the air would get in since as you point out it is a closed system. However, in the end result your story of what you went through to finally get your problem solved says that it could be any of the components. So if I understand you I should start with the master and then the line itself. Thanks for your help..Tony
    chubs likes this.
  3. Satterfield
    Satterfield Member
    Tampa, Fla
    08' Big Dog K-9
    Tony or "T"
    Thank you to everyone for your time and replies..Tony
    chubs likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    There is a vent hole in the cover, right behind the mirror stem, and if the seal is gasket is bad the leak could be coming from there
    #24 BWG56, May 1, 2017
    chubs likes this.
  5. PROFLYER
    PROFLYER SWOLE
    Supporting Member Full Member
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Rebuild the master, rebuild the caliper. Both very easy and cheap. Then refill and properly bleed it. $53 worth of parts.
    Master: http://www.wildsteedworx.com/index....ath=65_68_173_74_273_320_321&products_id=1530
    Caliper: http://www.wildsteedworx.com/index....ath=65_68_173_74_273_320_322&products_id=1179
    If you can't rebuild these yourself your shop certainly can. Find the dropbox link for the 08 service manual and you'll see how to do it. If not maybe another member lives near you and can help?
    bdm7250 and chubs like this.
  6. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Dropbox link..
    https://www.dropbox.com/home/Big Dog
    PROFLYER and chubs like this.
  7. bdm7250
    bdm7250 Guru
    Doug
    I just noticed that I don't have the 08 service manual in the dropbox, I will add it tomorrow at work.
    PROFLYER, BWG56 and chubs like this.
  8. bdm7250
    bdm7250 Guru
    Doug
    Updated with the 08 service manual..
    PROFLYER, BWG56, chubs and 1 other person like this.
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good job Chucky:old2:
  10. Lorenzo
    Lorenzo Active Member
    Ft Hood Texas
    2007 Big Dog K9, 117, 585 Cams, Heads decked .020, 6 Speed Baker Trans, V&H BR. 2011 Tri Glide
    Gramp's
    If youd like call me. i had the same problem and found the issue. 254-338-2066
  11. Lorenzo
    Ft Hood Texas
    Gramp's
    Yes it is a sealed system but i had the exact same problem not to long ago. Long story short, it was not a simple find. I found out that the PM calipers you can split them to do a rebuild, which is only 4 piston cup seals and 2 very small "O" rings. That was the problem, the 2 "O" rings in between the calipers when you split them apart, on one half there is a recess and small hole and other one is just a small hole. that's how the fluid passes between the halves. My calipers have never been split apart but the "O" rings wore out and seeped. As said by one of the other posters, no matter how small a leak or seep, if it comes out, air gets in. Sorry for the long post, JMO
    PROFLYER, BadDawg Bill and chubs like this.
