Left side under the tankWhat's the petcock? And does anyone know how my carbs are supposed to be dialed in? It's def a carb issue
I feel for you bro but you have a lot more problems than it won't start....What's the petcock? And does anyone know how my carbs are supposed to be dialed in? It's def a carb issue
Sorry, but I'd do the basics first. See if you can see fuel squirting in from the carburetor when you twist the throttle. If not look for a blockage and make sure your air filter is clean. If so make sure you get a good spark maybe change the spark plugs. If you walk into a shop and tell them I don't have a clue what's wrong with it be prepared to spend a lot of money. It sounded like you were just not getting enough fuel. Don't forget to charge the batteryNo won't run gonna take it in
When I'm at work and I get called to a machine because it's broke down. One of the questions I ask is who fucked with what and then we go from there.so i feel my buddy did something to it and now my throttle won't turn as much as it did?
