BDM primary lube ?
Discussion in 'Fluids!!' started by wtf33, Jul 15, 2012.
  1. wtf33
    wtf33 New Member
    Arlington Texas
    2004 BigDog Bulldog
    Kevin
    I need to refill the primary on my 2004 Bulldog. It has less than 2000 miles on the original fluid that the factory put in it. However I have already dropped that out and want to put the stock type/brand back in so that there won't be a compatibility issue possibly. With all the vast opinions of what will or won't do in this application I have decided to try and match the original stock fluid . Appreciate your time Dogpack ...:confused:
  2. DemonK9
    DemonK9 Active Member
    UT
    Big dog K9 2007
    K9
    Red line primary fluid
    Drain all your old shit out..... Throw in red line primary fluid........ You rocking and Rollin.
  3. Fibersnake
    Fibersnake Banjo Playing PsychoBilly
    Eastern Panhandle of West Virginia
    2005 BD Mastiff 2009 Buell 1125R
    2000 miles on the original fluid on a 2004. Damn time to change it even if the mileage is not that bad.
    I would just go with simple RevTech Primary fluid or something similar. Then get out and ride that baby and change it out routinely like, every other oil change, but at least once a year if possible.
    Cheap and good insurance
  4. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Yup RevTech here too! :2thumbs:
  5. 08mastiff
    08mastiff Active Member
    Clark, New Jersey
    2008 big dog mastiff efi
    John
    I use Bel-Ray.
  6. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    :2thumbs:
  7. TimNY
    TimNY Well-Known Member
    Upstate NY
    Home built/Frame up 2011 Custom - based on BDM Chopper, 2003 Roadking ,2009 XR1200,2002 HD Dirtster
    Guess
    I use Spectro heavy duty chaincase lube.
    I also use Spectro heavy duty 6 speed 75w140 in the tranny
  8. reloaderbmg
    reloaderbmg OLD DOG
    maitland fl.
    2007 k9,2003 road king
    IAN
    i thought 2004 bikes use atf
  9. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Revtec here but I'm noticing misses a gear sometimes and sometimes difficult to find neutral not sure if it's me or the oil.
  10. Trainguy
    Trainguy Chromeoholic
    Area 51
    K9 Karata 4" OP, V&H 2-1 S&S air+585, xo grips&pegs K&P oil & duel coolers, Ness, all chrome w/blk
    DJ
    X3 or so:2thumbs:
  11. wtf33
    wtf33 New Member
    Arlington Texas
    2004 BigDog Bulldog
    Kevin
    Thanks Gents for all of your response to my post. I know time is hard to come by. Keep the rubber down !!!! :flag:
  12. StreetHog
    StreetHog Active Member
    Scott City, Kansas
    2012 HD Street Glide, 2007 BD K9
    Pat
    Redline here...
  13. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    Premium Type F ATF here on both mine and Rocky's dogs. The only thing I would suggest is that you don't put 100% full synthetic as some have had slipping issues with that.
  14. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    Type F (Old standard Ford ATF) seems to be the choice, even by Baker Drivetrain and Energy One (clutch pack) who make the components.
    :down: on the synthetics.
  15. StreetHog
    Scott City, Kansas
    Pat
    So I got my K9 in I just bought. Just like my last one, I drained all the fluids and Amsoil the engine, Redline in the tranny and primary. No issues with my last bike with the redline but this one is causing problems with the clutch. I instantly noticed it. Can't get into neutral without shutting off the bike and when I start it and put it into gear with the clutch pulled it rolls forward. Per the "How to" section, I adjusted the clutch and cable and still same problem. Is it the Redline Primary Fluid???
  16. StreetHog
    Scott City, Kansas
    Pat
    I'm think'n it's the syn oil. Dropped it, pulled cover and clutch pack and cleaned it all up. RevTech oil on it's way....
  17. JMATHIAS
    JMATHIAS New Member
    anchorage ak
    2005 big dog mastiff
    Jason
    where is good stores that sell the redline or the revtech or is it order only?
