BDM Oil Cooler
Discussion in 'Fluids!!' started by ringo, Jan 5, 2012.
  1. BWG56
    BWG56 You all know I'm a liar
    Big Dog, SpyderF3
    Ker
    There is no wall, I have a tube on the inlet side to discharge the hot oil at the top of the cylinder and flow down and back out. The oil would be in contact with the outer wall and allow heat to disipate through the walls/fins on the outside.
  2. Fibersnake
    Fibersnake Banjo Playing PsychoBilly
    Eastern Panhandle of West Virginia
    2005 BD Mastiff 2009 Buell 1125R
    BWG56,
    That should work though I do not see a great deal of efficiency in it, but nonetheless it should provide some heat disapation as well as extra oil capacity. Is that tube going to be in postive contaact with the side walls. I it appears that the tube is being supported by the end cap and thus not allowing the end cap to be spun off if the tube is solid to side walls, if not and suspened, even less efficinet but still should provide some thermal transfer and cooling. Also just an idea, but if something like that was to be made, assuming it was CNC out of solid cylinder, than the far end cap could be made intergral to cyclinder since no need to remove. If being made out thick wall tube/pipe different scenario.
    Here's an idea to consider. You could go with larger tubing and have it precissioned fromed around a jig to exacat deminsion (so that the coils will be in constant contact with interior wall of cylinder-sort of an interference fit) and have it be one long coil with return up center of coil and swag to outlet. That way you would have lots of coil contact to the sides of cylinder for increase transfer and basically have a dry cylinder. Things to consider though is tube would have to be fairly larger to insure no undue restrictions that could result in improper flows. Just ideas
  3. Magoo
    Magoo Dog Locked
    Ft Myers, Florida 33967
    07 Bigdog Chopper, 04 H-D Heritage
    Ron
    I have an x-ray of a BD oil cooler, all it is, is a tube going up one side to the top and down the other. No coil, nothing fancy.
  4. BWG56
    Big Dog, SpyderF3
    Ker
    Fiber, no the inlet tube is not connected or touching the bore, and would spin off with the end cap, it is there only to pump the hot oil out at the opposite end of the cooling tube, the hot oil would be in contact with the inner diameter of the tube thus disipating some heat. Yes the bore could be a blind hole to eliminate the one end cap.
    This is just my idea of what I think it would look like, I don't have any intention of making one but thought I would share my ideas with you guys that are interested in making one.
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    For $300 bucks? :job:
  6. Th3InfamousI
    Texas
    Anyone have any idea how the Wimmer model is designed? Much cheaper than the BDM runs about $140 for the chrome 8" & $170 for 10"
    Oil Coolers
    Germanbiker likes this.
  7. ringo
    ringo Active Member
    Panama City, Fl
    down to ones with pedals
    OK, so heres what I got at the moment, no finite analysis or anything. One showing the divider method and the other showing the tube design.
    A bit of work for something that may not be needed.
  8. Fibersnake
    BWG56,
    Just throwing some idea around, but got thinking, (I need to stop that only gets me in trouble), but on the coil idea, without running numbers, it may be hard to do when you consider the bend radius of the tube (depends on material) and the relatively small inside bore. Also looking back it appears that you may were looking at a stash tube to use. which would be much easier and require less fabircation. So with that in mind, your idea would be the simplist and easy to make, not sure of how efficient but should provide some cooling for sure.
    Thanks for helpin me get the old brain in gear and putting it to work. Hell if I get motivated enough, may even dust off the FEA skills and see if could figure up numbers. Then again most likely will just enjoy my time with the family, breathing USA air and if the weather is not artic base go riding.
    Good luck
    #28 Fibersnake, Jan 11, 2012
  9. Fibersnake
    Nice CAD work Ringo! Hell even got the o-ring listed :2thumbs:
    Funny for as I think for some of this is just an excercise in putting some of ours skills to work (that is some cases such may have been awhile i. .e me for example) for as you indicated, for something most of do not need (know I have been fine for 7 years without one).
    Another idea to throw out there, plate and tube, Have some stacked plates made for fin with accurate holes, throw a small outside diameter plate between fin plates, run a large tube from one in up the plates, maybe 90 pass and back down the other side and on out. Only extra capacity would what the tube itself had, but would get more direct transfer for colling, would even be better if one could get a 4 pass into such and insure no excessive restriction in tube total tube length and diameter.
    Once again nice CAD Drawing
  10. BWG56
    Big Dog, SpyderF3
    Ker
    ringo,
    I would say that it seems we're sniffen up the same tree, we're pretty much the same in concept with your 2nd drawing:2thumbs:
  11. Germanbiker
    Germanbiker Active Member
    08 Pitbull / 13 MV Agusta Brutale RR
    Really good pricing!!
    Thanks for this post:flag:
    Jochen
  12. ringo
    ringo Active Member
    Panama City, Fl
    I have no idea of the internal make up, but with the very limited space in these coolers I highly doubt theres anything of novel design happening. They all work off the same principle (forced convection heat transfer ) I wouldnt suggest the 8 in model for a big twin.
  13. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    It woud be interesting to know what the temperature is going into the oil cooler and what the temperature is coming out... I cant imagine it would have very much retention time in the cooler to provide any significant drop in temperature..anybody have any data ?
    chubs likes this.
  14. Kiwirider
    Kiwirider Active Member
    Van Buren, MO
    08 Mastiff
    Dean
    I know this is an old thread, but here's my 3c. As the tube sits vertically. Have the inlet line finish at the cooler base (no internal tube) so the inlet is filling the cooler at the base of the cooler. Then have an internal tube from exit port to just below the top of the cooler (maybe 1/2" clearance). That way when you fill and drain the oil at service, the cooler will self purge the air from the cooler cylinder. If the tube was on the inlet side, it would hold a considerable sized air pocket. Something to think about.
    chubs likes this.
  15. Kiwirider
    Van Buren, MO
    08 Mastiff
    Dean
    I had a quick look inside the oil line ports on my cooler before I connected it today. It looked like there was a tubed side and a baffled side. They were both definitly different though.
    I connected the inlet line to the tubed side.
    chubs likes this.
