Anyone run a synthetic oil???
Discussion in 'Motor' started by DragonStang, Mar 15, 2014.
  1. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Mobil 1 here and I try and catch it on sale and buy it in bulk 12 Qts at a time at Advance Auto.
    Bdm4ever and chubs like this.
  2. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Here we go again...... :willynilly::willynilly::willynilly::willynilly::willynilly::willynilly::willynilly: :dupe:
    dentdude36 and chubs like this.
  3. Ghostflame
    Ghostflame Well-Known Member
    Hillsboro, Oregun
    Custom Softail Black, Billet and Chrome
    Scott
    I'm running Mobil One 15/50 also in mine as well.:yesnod::yesnod::yesnod:
    chubs likes this.
  4. 405bigdog
    405bigdog Active Member
    Shawnee, Oklahoma
    2006 hardly night train
    Chris
    When it goes on sale oreillys will match it.... Or they will match Walmart. We also stock chrome or black wix and kn filters.
    chubs likes this.
  5. jokester
    jokester Active Member
    Statesville, North Carolina
    1 bad K9
    paul
    Right!!! I think Sven should donate $$$. When you pay for somethin you respect it more..... , :rant:
  6. Sven
    Sven Well-Known Member
    building one
    No, I think you missed the point. I could give two shits how you say you need to get this off your mind is you did. Now, jump over my posts, pretend I'm not here. I do unto others before they do. Go ask Franco and see if any posts were answered or finalized for others, and this was before I showed up. Same shit around the net so either take the bike to some hack or do it yourself.
    See the cashier if you want me to get to the point. Theory is free in other words. I got paid [for a hobby] working on your generic bikes... name the brand they are all still pink inside.
    Because it's high tech and simple science at the same time and not my fault you do not grasp the handcuff of the abstract. And I'm not trying to be a dick. The OP has a simple or complicated problem to be addressed. I'm not here to fuck around when it comes to this shit. And just for you Paul, next thread I'm interested in and have somewhere to look, 'it's short and sweet.' Here's an example...
    Bdm4ever, francoblay1 and Viking like this.
  7. Sven
    building one
    ... It's not the oil used, it's how clean that air filter is maintained.
  8. BADOG
    BADOG Active Member
    LAS VEGAS, NEVADA
    2007 CHOPPER - 2013 BMW 1600GTL
    ROB
    Used to run Royal Purple throughout went to Mobile 1 ($7.95) a qt.) Lessened the vibration and noise a bit. Royal Purple is as thin as Canola oil.
    chubs likes this.
  9. Balls
    Balls New Member
    Harley,Yamaha,Triumph
    pretty slick wording bro...
    Unsprung and chubs like this.
  10. Balls
    Balls New Member
    It's not the kind of oil you use, it's the up keep of the oil filter...
    chubs likes this.
  11. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Well shit why didn't you just say so the first time man and save me ranting over reading that 2 page post lol..
  12. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    are we good, for now?????? granted, Sven is one difficult SOB to understand, but sometimes he can have some good meaning in what he posts. like i said before, maybe 5% of the people understand him 25% of the time. :cheers::cheers:
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    And sometimes he just a big ole Meat Puppet:oldhardlaugh::oldhardlaugh::sorry: couldn't help myself Sven
  14. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
    OK, my experience is not from motorcycles, but from heavy trucks. But with engines that can run north of $35,000 to rebuild, I have done extensive lab testing. And this is what I've found
    1. As long as the oil you use has the proper rating as specified by the engine manufacturer it will protect your engine as well as any other.
    2. Synthetic oils do not protect any better than modern conventionals. The benefit to synthetics is their reduced resistance to flow, thus providing better cooling capabilities.
    3. Oil does not wear out. It gets contaminated. In trucks we've found that with proper filtration we don't need to change oil. Simply change filters on a regular basis and monitor & replenish additive levelsas needed.
    Of course, I'm dealing with a unit that holds $500 worth of oil, I'd change oil in a bike just to save the hassle factor and for piece of mind.
    My suggestion is this,
    Change your filters twice as often as recommended
    Change your oil 1/2 as often as recommended.
    Have your oil lab tested every time you change the filters.
    Use whatever oil makes you feel warm and fuzzy inside. As long as it meets specifications.
    Lab testing has saved me a ton of money. It will let you know when something inside the engine is going out, usually long before catastrophic failure. I have found bearings that we're starting to wear through sampling that could have turned into a nightmare if it weren't caught well in advance.
  15. BigDogK-97.76of100
    BigDogK-97.76of100 New Member
    07 Big Dog k-9 LE 76of100 & harley fat bob 09
    Yep....fer sure......Synthetic.....Amsoil
    chubs and francoblay1 like this.
  16. Lorenzo
    Lorenzo Active Member
    Ft Hood Texas
    2007 Big Dog K9, 117, 585 Cams, Heads decked .020, 6 Speed Baker Trans, V&H BR. 2011 Tri Glide
    Gramp's
    Does anyone use Synthetic in all holes?
    francoblay1 and chubs like this.
  17. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Never seen a 15/50 there. In a 5 qt jug must be running standard automotive oil?
    chubs and BWG56 like this.
  18. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    synthetic in the primary tends to cause slippage for the clutch more times than not. motor and trans is a yes.
    chubs likes this.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree: with Mr Old Fart, :oldlaugh:
    I have never seen 15/50, 20/50 yes. I always change my oils yearly, whether its 2-2500 miles on the Dog, or 3-4000 on my vehicles and I use Mobil 1.:old2::whoop:
    #79 BWG56, Mar 21, 2016
    francoblay1, dentdude36 and chubs like this.
  20. Viking
    Viking Biker
    Florida
    I corrected it for you..... :chopper:
    chubs, BWG56 and dentdude36 like this.
