Anyone run a synthetic oil???
Discussion in 'Motor' started by DragonStang, Mar 15, 2014.
  1. liferider
    liferider Guru
    Louisiana
    Jonathan
    No for primary
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :yesnod::oldhardlaugh::oldhardlaugh:
  3. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    It is located on the driven pulley, right under the belt :oldsmile:
    chubs likes this.
  4. Deathstar88
    Deathstar88 Active Member
    Poconos , PA
    2003 Pitbull
    I have an open belt driven BDL Primary. Open primarys don't need oil. correct?
    chubs likes this.
  5. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Fuck yeah!!!!! 3 quarts! and make sure its synthetic!!! Donn´t fuck it up there.... it would be an expensive mistake!!! :chopper:
    :oldsmile: :oldthumbsup:
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Correct, we are just screwin around
  7. francoblay1
    K9 (2006)
    Franco
    Noooooooooooooooooooooooooo................. :job:
    :oldhardlaugh::oldhardlaugh::oldhardlaugh:
  8. francoblay1
    K9 (2006)
    Franco
    All you have to do is make sure the oil stays inside the open primary (if that makes sense to you).... you don´t want the oil dripping under your rear tire..... :panic:
    :chopper:
    BWG56, chubs and dentdude36 like this.
  9. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Primary should only use 32 oz
    20 oz in the transmission
    I think 3 qts for the motor
    francoblay1, chubs and dentdude36 like this.
  10. pauldeepsea
    California
    Paul
    Oh I didn't see that you have an open primary meaning a dry clutch
  11. Sven
    Sven Well-Known Member
    building one
    Between you and I, please say nothing to no one, they won't believe you. I'm talking about the squids out there. Here is real junk science from Cody the meat puppet is looking at all those dickheads and their oil threads, thinking that some oil additive in the oil will make the bike last longer... here comes the junk.
    It cost me the burning of skin off my arms to find out about DTT or computer function. So first bike was the crash mule and that bike burned oil because of a hard break-in. Mistake One. Second bike became test mule2 and again, hard break-in, maybe I didn't do it right? I changed it up a little. Mule2 burned oil so bad, I kept on adding oil before an average dump of oil @ 2,700mi. I trade that bike in for Mule3 the current bike. I break this bike in by the book. Not one drop of oil or sight window loss of oil come a 3k oil change interval.
    Meanwhile the junk going on were [also] these huge air cleaners to keep the air flowing at over 170mph test pulls. So say the average was about 135mph runups in short spurts were all 3 mules taking this abuse. Mule3 was broken in and now these [dyno like] pulls were going on with hack after map and you get the idea what the computer would react to hack after hack, combo hacks, hacks with maps, etc.
    Imagine the OEM air cleaners were coming out like out of the package almost. I could see what the bigger after market pleat would bring into the V of the OE pleats. Mistake Two pops up in the junk of the science. Mule1 has her compression tested. Book is checked hot @ 149 - 228 psi. The bike dials in at 220 psi with a cold test. So that little bit of oil was keeping the compression up that high I would imagine. Still not bad seeing that number and taking a guess of how much oil was leaking past those rings. That's hard break in. Mule3 is 241 against 261 on the high end, low end is 170 and change. Again, a cold test vs hot in book numbers.
    Where the junk of tests continue with the oil after the 600 mile break in. Bike takes 4qt to fill. All 3 bikes were receiving 2qt 50w racing oil. The behind the scene oil deals back then were if you were a B rider you received just a few cases. They had me in A rider grade and I received unlimited cases. So imagine all those years going by changing bike and car oil with this aging 39 year old oil; as I experiment with oils and break in procedures and find out for myself about some answers to engine life.
    To close with the junk in hand, Cody is sort of rubbing their noses in it for all those dickheads thinking they need to buy some sort of oil is I mix my oils. So junk tops off with any oil that is left around for the other cars. They run 10w30, and some delo from costco. Talk about thick backing down the driveway in gear with clutch in and a dead engine. Butter smooth shifts, and can tell the oil takes a shit about 2,600 miles and that's where the average comes in on the intervals.
    In conclusion, extend oil and those carbon particulates etching shit down is dump-dump-dump the shit out. Air cleaner is paramount. Any micron is the incredible shrinking man's bolder about to groove a chunk of wall like a chalkboard scratch down the cylinder wall, acts the snowball down a hill and grows that gap. Now, add those U and V-grooves up. I found out someone had matching miles [almost] and his pushed to 180psi against my 220. Didn't ask if was a warm or hot test?
    We are at a gas station and an indigent pops out of nowhere and says to me, "those air cleaners must be important to you." Such an intelligent man had that rolling in his head and I wonder if he figured it out? When others laugh at those things, I have the last laugh.
    Singed,
    NOLTT
    Bdm4ever likes this.
  12. Little-Boo
    Little-Boo Well-Known Member
    Troop Supporter Supporting Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    Mobil-1 , 50wt :old2:
    Carlos :old2:
    chubs likes this.
  13. pauldeepsea
    California
    Paul
    Sven is an idiot ! Not because he doesn't understand and know his shit! But because no one else can understand his dip shit postings!
    Fuck he is only asking about what oil to change!
    And you have all this other crap
    I haven't learned shit from any of your post. Get to the point please!
    I am glad you care but stop with all the crap and get to the point
    Sorry I am not polite but this shit is ripping the ass out of me
  14. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    ^X2
    Mobil 1 in everything.
    dentdude36 and chubs like this.
  15. chubs
    chubs Well-Known Member
    laf. indiana
    runky
    :hi: Didn't want to offend anyone, but you have expressed exactly how I feel about most of Sven's posts. If someone can't say something politely and coherently, perhaps they should refrain from posting at all. Just my opinion. and not meant to hurt anybody's feelings. :2cents::2cents::2cents:
    dentdude36 and Jwooky like this.
  16. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    ^X3
  17. pauldeepsea
    California
    Paul
    Unfortunately chubs ! I don't care if I offend people and I don't get offended when people express their feeling towards me! I speak my mind right, wrong or indifferent
    Bdm4ever, Jwooky and chubs like this.
  18. chubs
    laf. indiana
    runky
    :old2: Be assured that nothing you said offended me! I just had to agree with you about some of the offensive posts that have been made, demeaning members here (who actually do have Big Dogs).:2cents::2cents:
    dentdude36 likes this.
  19. Sven
    building one
    What I said was the oil and filter are the secret to keep changing the shit or the compression deteriorates.
    He fucking ask about longevity. Not my fucking problem you didn't catch the OP's main concern.
    Because I have fucking proof of it's not expensive oil that needs to keep some engine living longer. It's care and feeding of air contamination. All the oil did was glaze the break in and you saw two different compression readings, it's not the fucking syn,40 year old oil, not my fucking problem you did not decipher the OP or my leading up to keep the shit clean with any oil if you want it to last longer.
    I get to the fucking point each and every fucking time. Drag your ass thru it too LOL
    "Tormenting the motorcycling public one quart at a time" ..... LOLOLOL
    And stop flying yourself off the handle over some oil thread. Life is too short. They banned me over at triumphrat this month because 'I'm too over the top for that place or the net even' was the thought police comment. Giving me a warning to act like I neeeed to get to some fucking point(?) and on your terms is I said in no uncertain term was go fuck yourself tell me what to fucking do is FUCK YOU! Nor was I polite either.
    They were shown how fucked up their computer savvy their main guys were and to hear their abstract was so fucked up I told them WATT they didn't want to hear. Sounds like Donny is saying all the right things and now they want to ban him off the ticket. Sound familiar?
    Viking and dentdude36 like this.
  20. pauldeepsea
    California
    Paul
    I am all about saying what people don't want to hear. Think you missed the point . Appreciate you wanting to help but your post are really hard to read and worst hard to understand .
    chubs likes this.
