Anyone ever use this?
Discussion in 'Show & Shine' started by bdm7250, May 6, 2017.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Wow, looks like some good stuff:old2:
  3. bdm7250
    bdm7250 Guru
    Doug
    You're the man Kevin! Thanks a bunch..:old2::old2:
    chubs likes this.
  4. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    00 or 0000? I would think 00 would be a little ruff. Aluminum foil would be even better.
  5. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Y'all are holding out on us :old2:
    Thanks for the tips.
  6. Big D Florida
    Full Member Supporting Member Troop Supporter
    What causes the gold discoloration on chrome?
    Will this remove it?
    chubs and bdm7250 like this.
  7. Big D Florida
    Thanks Kevin... Probably what is happening in this case.
    chubs and PacoPetty like this.
  8. bdm7250
    bdm7250 Guru
    Doug
    I've done some research on the EPA regulations for chrome plating, read a couple times that the same standards were not adopted by Canada. On one of the sites it stated that due to this Canada is able to produce a far superior chrome plate. I don't believe very many opinions that I read on the internet, so does anyone on here know if this is true? I will be re-plating some parts on Sue's bike, gonna try a local plater in Toronto and wanted a bit of feedback before I pull the trigger. Thanks
    chubs, PROFLYER and PacoPetty like this.
  9. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I thought most of the regulations were regarding waste water and air filtration at the plants rather than any particular process changes. So not sure how it could be "better" although I don't know a whole lot. But I assume the platers have it figured out by now it's been 25 years since the last regulation.
  10. bdm7250
    bdm7250 Guru
    Doug
    I do believe it was 2007 that the last regulation was implemented, could be wrong tho.. As far as the process I think certain chemicals involved in plating were banned from use in the US and not Canada...again could be wrong. Just thought someone may know the inside skinny on this..
    chubs likes this.
  11. Th3InfamousI
    Texas
    What's really weird is we probably got a guy that does almost everything o. This forum but no chromers.
  12. bdm7250
    bdm7250 Guru
    Doug
    Hoping maybe someone knows about it..
    chubs likes this.
  13. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    I used to work at a chrome plating plant and they used cyanide in one of the very first dip tanks!!! The plater was one of the largest around. It took 1hr. 45mins to go from first tank to the last one!!!
    #13 ground pounder, May 7, 2017
    chubs, bdm7250 and dentdude36 like this.
  14. Rodwho
    Rodwho Member
    Naples, fl
    K9
    Rod
    I would suggest getting moisture from somewhere other than your tounge especially after the compound is on the wipe. Hate to think of ingesting this.
  15. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    Dent do you wet sand the motor? Thinking about doing it but don't want to screw up the professional polishing job
    chubs and PROFLYER like this.
  16. pauldeepsea
    Full Member
    California
    Paul
    Do you hit the area around the plugs? My fins are diamond cut and they don't take much to get a shine.
    chubs likes this.
  17. pauldeepsea
    Full Member
    California
    Paul
    You should get some chrome headbolt covers to clean that up
    chubs likes this.
  18. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    Holy crap that looks good! :oldwtf: I do not have the patience for that shit, :nonod: I should do it someday, but I am just too lazy, looks awesome though! :old2::old2::old2:
  19. bdm7250
    bdm7250 Guru
    Doug
    Well, Sue did order some of the blue job, and I ordered a bottle of the Noxon. We will see what works best. I have a feeling though that Sue will not be helping ...:oldbang:.
  20. Eric Schelin
    Eric Schelin Member
    Chesterfield, VA
    05 Bulldog
    Very cool man has covers with some buddies of mine and fighting it for a while very good post
