JIMS Throttle Bodies feature an Elliptical intake track, producing maximum horsepower and torque numbers throughout the entire RPM range. The “Elliptical Curve” starts at the air box and continues thru the Elliptical Throttle Body into the intake manifold. JIMS Ellipse 58mm Throttle Bodies have outstanding performance when installed on all EFI 2006 thru 2008 throttle cable style motorcycles. They are compatible with all O.E.M. electrical components (i.e. throttle position sensors, air control motors, fuel injector assemblies, etc...).
Not compatible with electric throttle cable style motorcycles installed on some 2008 models. The manifold is also wider to fit most taller engines. Use on all 100” to 131” Twin Cam® motorcycles. Throttle Body Kits are sold either with or without electronic components, MAP sensor, Fuel Rails, and Injectors.
