AMAZING 600 CAM deal
Discussion in 'Wild Steed Worx & Services' started by KaptinAmerika, Feb 27, 2018.
  1. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    For a limited time, "that equates to when their all gone", you can get a NEW 600 CAM for a whopping 99.95 plus 7.95 shipping(within the continental U.S.).
    That's almost $100 off the retail price.
    600 CAM on sale
    Any BD, properly equipped with roller rockers, can utilize this cam without special changes.
    WSW highly recommends upgrading to the programmable ignition module to get the most out of this cam but it is not required and you should have a better air cleaner that's washable.
    For those of you who just want to "Get Er Dun" WSW is offering the following complete package deal that gives you all the basic requirements to do the complete job:
    600 CAM Package Deal
    Get em while they last!
  2. JR03CHOPPER
    JR03CHOPPER Well-Known Member
    Orlando, FL
    2003 Big Dog Chopper, 2007 Big Dog K9
    JR
    That's a good deal!
  3. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
  4. Billy the kid
    Billy the kid Well-Known Member
    Gunnison colorado
    Bigdog Ridgeback 2006, 2010 Harley CVO ultra electra glide
    Wow, that’s a great deal!
  5. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
    How do I know if this would be appropriate for my 2007 K9?
  6. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    I have heard mixed information on whether you need to change the springs or not.
  7. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Seems like just a few years ago someone was saying anything beyond the 585 need the upgraded springs.
  8. Nཛ͢ཀཇཧ༏ཧי
    2007 K-9
    Shain
    I don’t see any inconsistency here. It appears it depends upon how your engine was equipped originally. If you click the link it says this.
    “WSW only recommends this cam for Big Dog motors with the larger valves and G carburetor. If you have the smaller valves, later EPA motors primarily, and an E carb and do not want to do engine modifications WSW recommends the 585 cam.
    Note: This cam will reduce your lower end power band, on stock Big Dogs, due to the low, roughtly 9.6:1, compression ratio and the stock locked Ignition Module in the Big Dogs. To really get the most out of this cam WSW recommends raising your compression a minimum of half a point and installing the Thunderheart Programmable Ignition Module. If you want to get the most from your motor without doing major engine mods go with the 600 cam and the Thunderheart Programmable Ignition Module.”
  9. SEAL-rider
    SEAL-rider Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb Thunderjet, V&H Big Radius
    Spencer
    I took advantage of this deal last week. Previously I had installed the 585 cam(now available with 13k miles), because I was unsure if I had the large or the smaller EPA restricted valves, but when my rear base gasket failed, I was able to confirm that I had the larger valves.
    I describe the difference as substantial. I don’t feel any low end torque difference, but at and above 3k rpm it is smoother, snappier and definitely faster. I hit 110 mph with ease and it was just stretching its’ legs. 110 is my limit(pussy), it’s not a Ducati. 3500 rpm is just silky smooth and it continues to pull without the sense of strain the 585 had or worse the stock cam. I did have to increase my main jet. Oh and my mpg went from 27 to 35.
    Big D Florida and Reddickracing like this.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I've never felt the 585 strain.:confused:
    bdm7250 likes this.
  11. pknowles
    virginia
    paul
    It might be above 3500 Rpm:)
  12. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Hard to feel the strain with it hanging on the wall...:rolleyes:
    BWG56, HMAN and pknowles like this.
  13. pknowles
    virginia
    paul
    I guess no tins takes away some of the strain too:oops:. I think i may have noticed less strain on the K9 when i rode it without the front fender but not quite sure;)
    bdm7250 likes this.
  14. bdm7250
    bdm7250 Guru
    Doug
    No worries here, I've got a 630 and lawnmower gas tank...no strain whatsoever.. :eek:
    BWG56 likes this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's true now, but when I used to ride it years ago it never stopped pulling right up to 5K, I'm sure others with the 585 would agree. But I never did like riding around in the 3500rpm range, its a cruiser not a sport bike, just sayin.:whoop::chopper:
    bdm7250 likes this.
  16. pknowles
    virginia
    paul
    1100rpm's is good. It'll heat the oil enough to burn off the moisture:)
    Reddickracing likes this.
  17. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    And there you go!
    BWG56 likes this.
  18. SEAL-rider
    SEAL-rider Member
    Del Mar, CA
    Spencer
    The 585 was a big improvement over stock. But the 600 takes it to a new level.
    BTW sport bikes live above 6k rpm. 3500 is not high rpm, and I don’t cruise there, but in the twisties or climbing ( SoCal is hilly), 3500 is a great place to be with a 600 cam.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    We ain't talking about sport bikes, and they don't have the low end torque of a 117, I live in the mountains and don't run 3500rpm's riding 2 up, I usually drop a gear.
    bdm7250 likes this.
  20. bdm7250
    bdm7250 Guru
    Doug
    My 630 Woods, along with the head work will pull your arms off in any rpm range..:D
    SEAL-rider, BWG56 and dentdude36 like this.
