Aircraft oil
Discussion in 'Performance' started by Bubba_BigDog, Nov 30, 2016.
  1. Bubba_BigDog
    Bubba_BigDog Redneck
    QC, AZ
    '08 Pitt
    Bryan (or Bubba)
    Anyone ever hear or use aircraft oil that's intended for air-cooled engines instead of standard oil generally intended for water-cooled engines?
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    Navarre,Ohio
    Frank
    Why? I think the synthetic oil is expensive enough. I would think anything that is aircraft approved would be pricey as hell.
    chubs likes this.
  3. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Mobil 1, 20-50w is intended for V-twins, not vehicles
    cdogg556, chubs and dentdude36 like this.
  4. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Yep, :oldsmile: same here, :agree: Mobil 1 is da chit! :old2:
    BWG56, chubs and dentdude36 like this.
  5. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    :yesnod:
    BWG56 and chubs like this.
  6. HMAN
    HMAN Well-Known Member
    fk it
    I would think all the extra additives would not bode well for our land based Dogs? Aircraft crap has tons of overkill built in for obvious reasons. I know our hydraulic oil used in our landing gear has lots of "extras" in it for high altitudes n such. However, AVGAS is the shit!! Jm .02
  7. Viking
    Viking Biker
    Florida
    Not on my Dog cause it is not needed, but on my boat, yes. I have dug out the mil spec and found marine oils that are identical to aircraft oils. Needless to say I do not pay too much for aircraft oils since I work in the industry, but West Marine and others charge you an arm and a leg for certain fluids. If you have access to get them and the mil specks are compatible, why not?
  8. Dawggydawg
    Dawggydawg Member
    Bethalto Illinois 62010
    05 Big Dog Mastiff, 2016 Harley Davidson Street Glide Special
    Mark
    Don't do it unless you want your S&S to die a quick death. I've been a licensed A&P mechanic for over 30 years. Aircraft reciprocating engines are for the most part air cooled, the oil used in them are vastly different than a motorcycle. They use a mineral based oil for break-in and then go to an AD oil (Ashless Dispersant). Aviation oils lack the friction modifiers required by motorcycle engines. They also never see the heat created by a typical air cooled motorcycle engine. Aircraft engine can also control their CHT and or EGT somewhat by having a manual mixture control and through the use of engine cowl flaps. But hey, if you want to try it, it's a free country. Just my 2 cents.
  9. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Yes! Whatever he said....ha
    chubs likes this.
  10. liferider
    liferider Guru
    Louisiana
    Jonathan
    Stay with my Royal Purple 20/50
    bdm7250 and chubs like this.
  11. BWG56
    BWG56 Guru
    Big Dog
    Ker
    I couldn't have said it better, well done :old2::whoop::oldlaugh:
    bdm7250, chubs and dentdude36 like this.
  12. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    CHT ( cylinder head temp) EGT (exhaust gas temp), im a licensed A&P too, CheersDawggydawg
    SKOGDOG, bdm7250, HMAN and 2 others like this.
  13. Th3InfamousI
    Texas
    After a few beers I bet you could have
    bdm7250, BWG56, chubs and 1 other person like this.
  14. BWG56
    BWG56 Guru
    Big Dog
    Ker
    :oldhardlaugh::oldhardlaugh:Fur sur :oldhardlaugh:
    bdm7250, dentdude36 and chubs like this.
  15. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :old2::old2: Yup that's the stuff, use Royal Purple in everything...
    chubs likes this.
  16. badyellowvette
    badyellowvette Active Member
    North Central PA
    2008 K9
    Jim
    I ran aircraft oil in my Sportster in the 80's. Bought a case somewhere, it was even in the old metal cans. Some old biker guy recommended using it, never seem to hurt it any. Don't think I would try it in my K9.
    chubs likes this.
