Advanced Maintenance
Discussion in 'How-To' started by Raywood, Sep 23, 2011.
  1. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Most all my wiring is shrunk wrapped with die electric grease. But never done anything to the hand control boards and never had a problem with them.
    Have a great trip
    Sent from my DROID RAZR using Tapatalk 2
    chubs likes this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Thanks,
    That does provide me comfort in knowing you have ridden the piss out of her and no issues on that front! :flag:
    I am looking at hopefully doing 2-2.5k miles 3rd week of October. Taking off Oct 20th and not returning until Oct 27th. Haven't figured out where to yet. With it being 3rd week in October I'm fairly limited to stay South I just haven't figured out if East or West is the way to go from Dallas. I am open for recommendations, I was considering Arizona/Southern Utah.
    chubs likes this.
  3. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    if you come over this way, keep a long eye out on the atlantic for hurricanes/tropical storms. season runs til november.
    chubs likes this.
  4. KnotSo
    Western Washington, the State
    :2thumbs:
    chubs likes this.
  5. Rottweiler
    Rottweiler Well-Known Member
    Elizabethtown, PA.
    2004 Chopper, 2014 HD Road King CVO, 1985 FXWG
    Todd
    Great job Ray,
    Just wish the picture moved with the new site layout. Getting ready to do some work on mine and a picture is worth a lot. :(
    chubs likes this.
  6. Rottweiler
    Elizabethtown, PA.
    Todd
    Well got my front caliber rebuild kit along with some other goody’s from Wild Steed Worx The Kaptin is the man and fast too. :old2:
    Disconnected the from brake line and taped up. Removed the two caliber mounting bolts and set up my tail gate as a work bench. Removed the four allen bolts holding the two half’s together. Removed the brake pads then cleaned as much as possible and put it back together with the two center bolts snug. Cut an old paint stirrer up into pieces around the same length as the pads. Use three at first then two put them where the pads were. Got my air hose blow gun rapped the end with with black tape then blew some air into the brake line hole. This popped out three out of four pistons most of the way, but not all the way. Push the two back in some and use the same size allen wrench as the four bolts, put it between the wood and the side that was stuck. This held the wood closer to the side that was loose. Hit it again with air and it moved a little more. Took both half’s apart again and removed the pistons. Now for some more cleaning. Here are some pictures.
    chubs likes this.
  7. Rottweiler
    Elizabethtown, PA.
    Todd
    Had my head light out last year when I replaced the tach ring that Kaptin rebuilt. That fixed most of my electrical problems. Head light and connector look great then. Last year I lost my low beam on the way back from O.C. bike week. So back apart again removed set screw for beauty ring then ring, Then other set screw just a little, not sure what size it was, did not have any that fit? :oldswear: Removed retainer ring with a small punch in the four holes. Be very careful with this. :oldcool: Take your time switching back and forth from side to side with the punch. The stock socket is junk. :olddown: Replaced with WSW connector. Comes with nice instuctions too. :old2:
    Big D Florida, francoblay1 and chubs like this.
