Accutronix and S&S Velocity Stack bracket install
Discussion in 'How-To' started by mudslinger, Dec 1, 2007.
Thread Status:
  1. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    OK as you may know I bought the Accutronix air cleaner and a S&S G Velocity Stack Chrome Billet Breather Bracket.
    So I figured since I was taking the stock air cleaner off and installing the new one I would take step by step pictures.
    OK here goes.
    First off you need to unscrew the outside cover (3) screws.
    you can use a standard alan key.
    Once those are unscrewed take off the cover. You will see the filter.
    Now take off the filter and you will see the 3 screws holding the outer intake backing to the carburetor. Unscrew those now.
    Once those are lose now start unscrewing the breather bolts up top.
    Now you can remove the backing and start removing this hose from behind the backing.
    From here you can start removing the hose from the top breather bolts leading to the filter. This will no longer be used.
    Once your intake looks like this it's time to take the actual breather bolts out.
    Now it's time to line up everything before install. Make sure the gaskets will seat properly. And the bracket sits in the proper position.
    (Nothing lined up for me. All the wrong parts 3 hours of reshaping the bracket. Rotozip and drill work. The bracket was over an 8th off but I made it work).
    A little work but it's starting to come together.
    This is what the bracket should look like installed.
    Yummy chrome.
    On to the next problem. Since I bought a S&S E G Velocity Stack Chrome Billet Breather Bracket ,which is thick billet my screws were to short that came with the Accutronix air cleaner.
    I had some same thred bolts that would work but would have to do a little grinding to get them to sit right.
    No problem!!!!!!!!!!!!
    OK we just past all the hard stuff. Now to fit the filter and cover.
    On the Accutronix air cleaner there are about 12 Alan head bolts securing it to the filter and backing. So to line up all of them and keep the spacers in place I place scotch tape across the heads. Just so when I was lifting the cover on they would not all fall out.
    fasten the cover nice and tight. and look-E- look-E-, LOL[​IMG]
    Don't mind the messy garage.:cheers:
    #1 mudslinger, Dec 1, 2007
    Oscar Maldonado and Tim like this.
  2. chacha
    chacha Chaff Your EHC!!
    Full Member Calendar Participant
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Dat is freak'n SWEET MudSlinger! Damn fine job on the pics....:up:
  3. seatmaker
    seatmaker Well-Known Member
    Full Member
    Spitten distance from Hell,Michigan
    2012 Ultra Classic
    Sounds like you and I have the same luck. Looks good , especially the pink air filter. Just Razzin ya :rolleyes:
  4. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    Looks good Mud.
    For a good source of chrome bolts try Keck Hardware on West Rd in Trenton. best selection around.
  5. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    Yea,:2thumbs:
  6. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Thanks a lot guys.
    Im glad it came together I have to get a small filter tomorrow for the 3rd hose. I will put it on in the morning.
    I have been looking for that place ,LOL
    Im going to check that out too. Thanks.
    Just can't wait to get the new pipes on now.
    Then I can do a photo shoot for the bike :D
    Some time this winter I will be sending some covers out to be engraved.
    I came up with a new theme for the bike. Let you peeps in on it soon.
    On a side note I have not drank in 3 days can anyone tell, LOL
    #6 mudslinger, Dec 1, 2007
  7. KnotSo
    KnotSo Admin
    Washington
    Mud, is the new filter bigger than the stocker?
  8. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    No way smaller, that was a let down.
    But it kills the other one in looks.
    would have been nice If the filter was bigger.
    But i have a mod comming for that to.
    I will be replacing the spacers with longer ones to get a bigger filter in there.
    #8 mudslinger, Dec 1, 2007
  9. LamboV12
    LamboV12 Active Member
    Full Member
    Ormond Beach
    K9
    Frank
    Nice job Mud - after reading your other posts - well done!
    I'm running a stock S&S tear drop cleaner and might switch to this -
  10. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Added breather!
    I added the breather filter to the 3rd hose.
    Here is how it looks.
    Look under the oil tank.:whoop:
  11. Gas Man
    Metro Detoilet
    Might want to run that between the motor and tranny. Wouldn't want it to leak on the chrome.
  12. ohio dog
    ohio dog Active Member
    Akron, Ohio
    04 BDM Chopper 107"
    don't see any breather head bolts? Gas is right...oil and hot chrome does not mix. Shit can be hard to get off!
    #12 ohio dog, Dec 1, 2007
  13. chacha
    Looks good MudSlinger. Who makes the filter you added to the carnk vent? I've not seen that one before -- nice!
    Don't worry about the chrome...the oil mist ain't gonna hurt it.
  14. P8RIOT
    P8RIOT Well-Known Member
    Kirkland, WA
    2007 K-9
    Here's how mine's mounted, tucked just inside the pipes, on a chrome bracket attached to the bottom forward tranny bolt. From this angle it is a little hard to tell, but it is at the same height as the lower pipe, making it is almost invisible except at this high viewing angle.
  15. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    OK the breather head bolts are integrated to the bracket.
    The bracket has a hollow track in side of it that feeds from the filter.
    It is an S&S velocity stack bracket.
    lee likes this.
  16. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    OK I will reroute it tomorrow.
    :flag:
  17. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Thanks !
    It's a APC they bought out Pilot.
    They actually stopped making the smaller ones 3 months ago.
    So I was told.
  18. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Awsome job!
    Looks great.:)
  19. ohio dog
    Akron, Ohio
    04 BDM Chopper 107"
    Pretty cool......looks great too!
  20. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Thanks !
    Next week the new pipes and coil cover go on.
    Should start to look pretty nice for this spring.:cheers:
Thread Status:
