65 tooth vs 70 tooth
Discussion in 'Transmission / Drive' started by Coolbreezin, Feb 7, 2017.
  1. Coolbreezin
    Coolbreezin Active Member
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    How much of a difference will 5 more teeth on the back make in regards to rpm at 60mph? My rear pulley came apart and shredded my my belt. Im having a hard time finding a 65 tooth that I like. Also, how many teeth will I need on the belt if I go to a 70 tooth?
    I remember in the sportbike world it was 1 down in the front equals 3 up in the back. Not sure if that applies to our application.
    chubs likes this.
  2. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    What pulley did you have on you're bike? Did you try Bigdogpartsking
    chubs and bdm7250 like this.
  3. bdm7250
    bdm7250 Guru
    Supporting Member Full Member
    Hamilton Ontario Canada
    Doug
    Try here.
    http://www.ebay.com/sch/i.html?_odk...+tooth.TRS2&_nkw=big+dog+65+tooth&_sacat=6000
    chubs and bigkelk9 like this.
  4. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Ive been rolling for the past 2 years on a DNA Demon pulley. Ive contacted Outlaw Cycles twice with no reply. kjhgv.jpg
    chubs likes this.
  5. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Ive contacted Shovelhead kicker about a replacement. But Id rather not use a BDM OEM pulley.
  6. bdm7250
    bdm7250 Guru
    Doug
    Your pulley only lasted 2 years?
    chubs likes this.
  7. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    They sell em on their site and the new ones are supposed to improved and way better.. someone here just recently got one.. can't remember who.. but someone might chime in
    chubs likes this.
  8. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    Yes, 3 arms.
    Yes, 25 months.
    chubs likes this.
  9. bdm7250
    bdm7250 Guru
    Doug
    chubs likes this.
  10. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    chubs, bdm7250 and dentdude36 like this.
  11. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    My first tow home with the new headlight. lol
    Kind of hard to see but the inside wall of the pulley separated from the center part. Thats what shredded my belt.
    chubs likes this.
  12. bdm7250
    bdm7250 Guru
    Doug
    :old2::old2:
    chubs likes this.
  13. FrankBDPS
    Full Member
    North Lawrence,Ohio
    Frank
    Was the belt running off to that side? There sure wasn't much material holding that side plate on.
  14. bdm7250
    bdm7250 Guru
    Doug
    Ya get what ya pay for..
    chubs likes this.
  15. Srodden
    Srodden Well-Known Member
    Full Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
    Looks like there was some pressure in the wrong place. Side pressure, mis alignment, belt too tight there shouldn't have been any reason for the pulley to do that if the belt was running neutral in the middle.
    Just curious was pully billet or chromed ?
    chubs likes this.
  16. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    :agree:
    chubs likes this.
  17. blacktopper
    blacktopper Active Member
    Full Member
    Pittsburg Kansas 66762
    07 K 9, 08 Ridgeback, 10 K9
    Did the screws come loose that hold the inside plate to the body?
    HMAN likes this.
  18. Coolbreezin
    Full Member
    Northeast FL
    05 Ridgeback
    Pete
    1 Sides are welded on.
    2 Belt was true for the past 10,000 or so miles. I fail to see how it suddenly shifted. The inside of the wall would shine like a mirror from all the rubbing.
    3 True, you do get what you pay for. I spoke to DNA and they told me that that the Demon pulley wholesales for more than I bought it for, so we think it was a leftover that the seller wanted to get rid of.
    bdm7250 and chubs like this.
  19. Srodden
    Full Member
    Flint, Michigan
    Scott
    One more thing I see those rims those were on a recall. Are they original to the bike ?
    chubs likes this.
  20. 1mndg
    1mndg RIDE IT HARD!!!
    Pottsville, Pa.
    2004 Chopper DT
    Bob (1meandog)
    A 70 tooth pulley compared to a 65 will change all gearing by 3.25%. Lower.
    chubs and Coolbreezin like this.
