john sachs
:2thumbs: :2thumbs: :2thumbs:RB Racing
LSR 2-1 Customs
LSR 2-1 Customs
Stamped right on the cam. You'll need to pull cover off to verify or possibly pull cam out to read the numbers. IMHOis there anyway to tell if the engine has a 585 600 or else cam? like if I open the cam cover would the cam itself have it written somewhere? I have the 07 k9 with the 117S&S diamond cut.
That would be a good bet...:2thumbs:Well I bought the bike from an old guy in Tampa with 400 miles on it... had Tampa DBM do the first serviced before I rode it down to Miami and shipped it to costa rica.
I guess I'll have to open the cam case and see what it has in there, but from what I've been reading its probably the stock one.
Anyone know what the 04 107 Rigids have? I read that same line in the manual and I just don't understand how they have a 520 or 600? Just seems like a massive difference.This is what the BDM Service Manual 1994 ~ 2004 says on page one.
"107-inch S&S (Big Bore) motors are identified by the SA (Special Application) stamped near the serial number on the motor cases. S&S 107 inch motors will have either the S&S 520 or 600 camshaft installed."
So... glad this came up, according to S&S, these engines crate came with a 600, the gap from the cylinders to the heads was smaller, and the valves were different, ours came epa resulted as to why they have what they have so when I did my rebuild aside from boring my jugs and throwing Carrillo pistons in it, was to their specs. Supposedly it’s not for the power, but it’s over all better for the engine itself.and 8 years after...........
Yeah, when I had my heads redone, they put new valves and springs in and all that... but riding Dahlia is night n day difference for sure now.. but yes, a simple cam change just don’t do the trickAs I have said in previous threads, because I had an E-carb I had to limit to 585 cam. After I got the G-carb, I kept riding the 585 cam and it continued strained above 3800k although better than stock. A friend gifted me the 600 cam and the difference was amazing. It pulls without strain through 5k. The biggest concern for the 2005 117 is valve size. If you have the small (epa) valves which have weaker springs you can't take advantage of the 600. I was lucky that I happened to have the larger valves.
Who be this "randy" you speak of, so I know not to use, never heard of him on here before that I recall.But I will however warn whomever not to use Randy, he spin dropped my heads and they have never sealed correctly, he should have just shaved my jugs. My bike has leaked oil from day one of getting it back from the heads so I’m not even fully experiencing the full potential of that rebuild...
