585 change
Discussion in 'Motor' started by myanoch, Nov 22, 2009.
  1. V
    V Guru
    If you have the "red stripe" springs make sure there are 3 springs in the "spring pack" an outer, middle and an inner spring. I have seen a couple of take off sets at the dealer that were only 2 springs
  2. 05 old dog
    05 old dog Well-Known Member
    Full Member
    liberal kansas
    05 bulldog
    billy
    any noticable difference going from the .569 to the .585 or would this be a waste of bucks??? got an 05 epa dog...
  3. PaulHart
    PaulHart Well-Known Member
    Oklahoma
    2009 Mastiff
    Paul
    The more posts I read on engine performance. The more confused I get.
    I want to change the exhaust, carb and go for a slightly more than stock cam I guess. Who wouldn't want more power. But I don't want to hurt reliability. Of course I hate EPA shit on anything. Trucks, cars and bikes whatever. NO GOOD. And then ignition too if necessary.
    So i guess It's a 590 or below cam. Choice of carbs. XXX, PSI or Mikuni. R&R Racing LSR pipes.
    And some kind of ignition. ????:crazy::willy_nilly:
    #63 PaulHart, Dec 14, 2010
  4. BFB
    BFB Bad dog, no bisquit
    Carlisle, PA
    2008 Mutt,Honda CRFX 250,2013 Streetglide
    Brad
    Hey Stryfox. Ordering a 585 for my Mutt as well, but won't get to install till later this winter. If you are doing the install, how bout some pics as you go. Im not a great mechanic but get by with a little help from my friends and Jack Daniels. Unless some body has already posted pics of install, I could not find.
  5. stryfox
    stryfox Active Member
    2008 Big Dog Mutt. custom suzuki intruder
    Ups tracking says it should be here today.
    I am hoping to put it in on Friday.
    I will try to remember to take pics.
    I could be wrong but it seems the hardest part is adjusting the push rods.
    There are some great how to's on push rod adjustment here.
    Any tips from the guys here that have done it to help.
    You know, the non obvious stuff?
  6. armad
    armad Active Member
    upper midwest
    08 Mutt, 06 Warrior, 99 Roadstar
    Where did you buy the cam? If you don't mind, what was the cost? Are you putting in new lifters too? Keep us posted on the install. Thanks
  7. stryfox
  8. MisterMister
    MisterMister Active Member
    Little Rock, Arkansas
    2008 BigDog K9
    Larry
  9. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Look at post #'s 39-40 there are a few pics.
  10. stryfox
    Haha...took cam cover off and just realized I forgot to order a gasket.
    Step one. Remember to order gasket and cam.
    Step two. Disassemble.
  11. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    There is two different gaskets for our covers take a look before you order one. Any Harley dealer or aftermarket should have one.
  12. V
    V Guru
    Also did you get some shims with your cam? You need these to have the correct endplay, which i believe is .005-.015
  13. stryfox
    Had some free time so I installed the cam tonight.
    It was an easy job. Endplay checked good with the factory shim.
    I need to pick up a new gasket tomorrow. I fit it with the original gasket.
    The gear seemed to measure out ok too.
    Did anyone have to press off the gear and put the old one on?
    Push rod adjustment was straight forward with the how-to section on this awesome site.
  14. V
    V Guru
    Just a note and i may be stupid for bringing it up. But if you change the gasket out you will have to loosen the pushrods and re-do the pushrod adjustment. Just sayin.
  15. stryfox
    I was able to remove the cover after the lifters blead down.
    Will this really effect the tappet adjustment?
    Thanks
  16. Trainguy
    Trainguy Chromeoholic
    Supporting Member Full Member
    Area 51
    Big Dog Motorcycle Enthusiast
    DJ
    Of all the threads on this cam, this is the first i have seen this number. 109 to 127 on the torque side, that is what i'm feelin' in the seat of my pants with mine:2thumbs:
  17. stryfox
    Ha ha just put it together. I found out what you ment.
    Good thing I'm not trying to make money on this one. :)
    Hey at least doing it twice I'm sure I did it right. :)
    May tins and tank are at my shop in basecoat so I can't run it yet.
    I'm assuming everything will work as planed but won't know for sure till I fire it up.
    Honestly this was a simple job. Don't be afraid to try it yourself.
  18. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    did you remove the lifter blocks or how did you hold the lifters up in the blocks while removing/installing the cam.
  19. stryfox
    I removed one lifter block to check the end play.
    Even with the lifter blocks in with the pushrods all the way loose. You can just push the lifters up from the bottom with your fingers and slide cam in and out.
    With the timing marks line up I only had to hold 2 lifters up.
  20. troppushcet
    troppushcet Member
    07 K-9 Flat Black
    You can change your stock cam to a 600 cam without doing any changes to your heads or cylinders. There is penty of valve clearance for the change.
