585 Cam Install on '09 K9
Discussion in 'How-To' started by Bowhunter, Apr 9, 2011.
  1. Bowhunter
    Bowhunter Well-Known Member
    Full Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    Thought I posted that part # before in my install thread, but here it is if I didn't: Part #25225-70C, I paid $3.99 at the local H-D dealer.
  2. Que
    Que Member
    Mandeville
    2007 Big Dog Chopper
    Cam swap! Did you say cam swap? My Dog has been down for months doing a major rebuild. I started just replacing the transmission again due to the nut backing off the shaft causing the input shaft to move and loose all shifts. Then I looked at the base gasket leak that has been getting worse and decided to change out the gasket. That turned into a fresh set of pistons with the shorter cylinders which meant a 600 cam would work nicely now. Then decided to install the cam with new lifters. While waiting on the transmission to come back from Baker I wanted the Baker Belt Drive. You guessed it, I ordered the belt drive. Got all the parts in and was waiting on the cylinders for about 2 months. Guess they were made in China or something. While waiting I looked at the heads and decided to freshen them up. Sent them off to have new guides installed and a valve job. Couldn't wait to install everything so I could make it to Thunder Beach. Stayed up late working on the Dog. Took a break once I got the heads on and went to sleep. Woke up and started to work on the Dog when I noticed the first 2 fins on the NEW front cylinder had a CRACK!! Now waiting for a new front cylinder. I think it will be cold before I get this bike back together.
    Oh yea, you were talking about a cam swap huh? Sorry I got carried away.:loony:
    #42 Que, May 16, 2012
  3. Tomtang aka Reptilejim
    Tomtang aka Reptilejim Well-Known Member
    Shreveport, LA
    2006 big dog ridgeback
    Marvin
    Thanks for the info Steve!
  4. Bowhunter
    Full Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    No problem, glad to help.
  5. ronson1977
    ronson1977 Member
    South Shore MA
    2007 ZX-10R SE, 2008 Mastiff LE
    Thanks for that part number Bowhunter and for the awesome how to that I'll be using to do the job. This forum is the shit. To the technical few that keep us bumbling majority riding! :cheers:
  6. ronson1977
    ronson1977 Member
    South Shore MA
    Rode some if the snake on the NC side of TN. Sweetest day of riding in my life. Real knee dragger turns, excellent country in the US:flag:
  7. ronson1977
    ronson1977 Member
    South Shore MA
    Stupid drain plug! Now I need to go get allen sockets. Why couldn't they put a reagular bolt plug?:bang:
  8. francoblay1
    francoblay1 The Spaniard
    Full Member
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Bump
    [/QUOTE]Originally Posted by nine lives View Post
    Bowhunter, not to rain on your parade but, when I do a cam, I usually remove the tappet blocks to have access to the cam from the hole In block where the tappet blocks mount. Why? Because I check for cam end play by installing the cam, mounting nose cone and new gasket. I then use a feller gauge to check end play. I add or remove shims for proper end play. I understand that you measured the cams length so you would assume that the shims would be the same. But if the cam you removed was not shimmed properly to begin with or the bearings seated, or ware etc., you would have improper cam end play.
    I have had cams walk which intern causes the cam lobes to ware improperly from the load not being centered on the cam lobes from the tappet rollers. There is more work involved, but I feel doing it this way is the best way to preform this swap.
    Could you post a "how to" w/ pics on these additional steps for those of us less inclined?[/QUOTE]
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Thanks Bowhunter, I just installed my 585 cam following your instructions and it was a breeze. Now I'm onto adjusting the valves. My 585 was within .001 of the old cam width.:whoop::whoop:
  10. Bowhunter
    Full Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    You are welcome Ker, glad that my photo visual helped you do your cam.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The new .585 cam I installed was stamped with .592 on the face of the cam gear. The part no and box from S&S was marked correct. S&S does not list a .592 cam, does anyone have any thoughts on this?
  12. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Got a pic? More lift for the money :cheers: cam gear may have been stamped wrong....
  13. reloaderbmg
    reloaderbmg OLD DOG
    maitland fl.
    2007 k9,2003 road king
    IAN
    good job! [rep power!]:2thumbs:
  14. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    No pic, sorry, I closed it up already and now I'm pissed at myself for not taking one before I closed it up. I've never worked on a motorcycle motor but after doing this myself with the how-to's on here, I could proly do this in 4-5 hrs again (to go back to stock) if it causes other problems.:confused:
  15. erldawg
    erldawg Guru
    Full Member
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Now that I think about it if there is a identifier stamp for the cam it should be on the cam not the cam gear.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    It was right on the face of the gear along with the 2 stamped dots for alignment with the crank teeth. If it was machined to be a .585 I would think .592 is out of spec and they would have reground it to .585 unless they sell a .592, which they don't.
    I don't think its any big deal just very odd.
  17. Jamesl0822
    Jamesl0822 Member
    2005 Big Dog Chopper
    Here is mine....Cam Gear is stamped 592 and Cam is stamped 585
  18. makithapn
    makithapn Member
    Ft Myers Florida
    2006 k9, 2006 Texas Chopper, 2008 Road Glide
    Les
    super job Steve, :cheers: what kind of fuel milage did you get befor the swap?
  19. Bowhunter
    Full Member
    Oliver Springs, Tn.
    2009 K9
    Steve
    I might have lost a little, but it is about the same mileage as I got before the swap.
    Trainguy likes this.
  20. Jamesl0822
    Jamesl0822 Member
    Just got done with this install and the hardest part was putting the freaking pushrod tube covers back on.....fun!! This thread helped me a bunch, Thanks man
    chubs likes this.
