2009 bdmc wolf died
Discussion in 'Help Wanted' started by Christian D Savoie, Jul 9, 2018.
  1. Christian D Savoie
    Christian D Savoie New Member
    Geneva fl
    2009 bdmc wolf
    Chris
    I pulled into a gas station and when I went to start it I accidentally cracked the throttle a hair bit as I was pranking it made it backfire and then just spun over real freely I got it home by way of tow truck. I looked at the THC and noticed that the power light which is yellow is steadily on. Across is green flashing light aka controller on.. when I turn key on all ehc lights turn on and then off and the yellow and green light as mentioned earlier stay on. X even as I spin motor no lights change on ehc. I have spark and feul but no start EHCFaultleds-1.jpg
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    check your compression releases.
    Does it sound like its trying to start at all?
    When you checked for spark, did you check that the engine is turning over not just the starter spinning/ primary moving?
    Do you have compression?
  3. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    Yes I have compression. I'm unaware of the compression releases. Wolf supposedly dosent have them
  4. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Did you check BOTH cylinders for compression?
    I don't know much about the xwedge so didn't realize no CR's
  5. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    do you hear it trying to ignite the gas at all? ie trying to start? or just spinning freely.
  6. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    I took plugs out and layer a towel over each cylinder and when I started it the towels blew off . I don't have a gauge (yet)
  7. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    Spins faster then I ever heard so sign of trying to start
  8. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
    I believe that your motor has a timing belt / belts.
    I would be checking the belt.
    Paul.
  9. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    and I believe the early ones did have problems with the belts. not too many of the Wolfs around so not that much knowledge about them.
  10. pauly
    pauly Active Member
    Paul
  11. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    how would I have fire to the plugs if the belt was broke? how would I have compression?
  12. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
  13. pauly
    pauly Active Member
    Paul
    Your motor is still turning over and your pistons are going up and down mowing air in and out the spark plug holes and
    your ignition would still be working normally.
    Just take the cover off and have a look at the belt and replace it even if it is ok.
    Those belts have a tendency to break from heat of the motor.
    Paul.
    SKOGDOG likes this.
  14. pauly
    pauly Active Member
    Paul
    If you have compression tester measure your compression.
    If the belt is broken the compression will be very low or none.
    Paul.
  15. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Pauly is right as rain--just look at the belt to see if it's broken (if that is the issue). Take off the cover. If it needs replaced, you should put a couple of washers on the cover when re-assembling it. That allows air to dissipate the heat. They added the spacers in later production...very simple and effective fix. Be sure to clarify the timing procedures with S&S or a manual.
    The good thing is that the pistons do not contact the valves when that happens, so you just have to replace the belt, and add the washers.
    Call S&S (608-627-1497). In 2015 there was an X-Wedge specialist named Brent at X1242. Or ask for Chris Clemens...they are always happy to help.
    As I recall, instead of compression releases, is a variable camshaft that incorporates a bump to the valve when starting, then shifts to normal camshaft lift and duration when the engine starts. If memory serves me correctly, the earlier 121's did not have that cam. Again, someone at S&S should be able to tell you if your engine has the improved cam or not. I would plan to install one if yours does not.
    chubs likes this.
  16. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    I jus took my timing cover off and belt is toast
    Srodden likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    And there ya go :oldbang: bummer, but ya at least have your answer. Good thing its not an interference motor:old2:
    Christian D Savoie likes this.
  18. SKOGDOG
    Pittsburg, Kansas
    Rick
    Thanks for the follow-up. That is probably the cheapest thing that it could be—no big shop costs, etc.
    Either S&S or D&D (Shovelheadkicker) can fix you up.
  19. Christian D Savoie
    Geneva fl
    2009 bdmc wolf
    Chris
    I've replaced timing chains in small block chevy
    Is there any particular way this should go on?
  20. pauly
    pauly Active Member
    Paul
