2008 K-9 Rear Rotor
Discussion in 'Brakes / Suspension' started by Jersey Big Mike, Dec 15, 2015.
  1. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Full Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Need to replace mine Warped/bent (disc lock -- don't ask).
    Curtis - Do you still have the outsides?
    Do I have to replace it with another "floating rotor" or can I use a fixed one piece (much cheaper)
    As always guys -- thanks in advance.
    I'm loving living in SC -- Got out on the bike again today (twice actually -- Mid Dec -- love it)
    chubs likes this.
  2. Mr. Wright
    Mr. Wright Guru
    Supporting Member Full Member
    Salem, Missouri
    Shannon
    chubs likes this.
  3. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    Yes I have the friction disks in stock.
    You will likely need to have the center hole milled slightly to fit the BD hub but technically you can replace it with a solid rotor.
    Friction Disk
    chubs likes this.
  4. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Were all 2004 models not a solid rotor? I know on my ridgeback I have a solid rotor just don't want anyone to get confused based on the listing. I had thought the rotors and buttons came 05+?
    chubs likes this.
  5. pknowles
    virginia
    paul
    I have hooked up to different people in the last couple years with rotors that came off an 07 heritage softail. Like Curtis said, I had to get our machinist to open up the center just a tad. If you go this route, make sure you get the one that matches your thickness as the Harley ones are two different sizes.
    chubs likes this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Good to know:old2:
    chubs likes this.
