2007 big dog bulldog fuel injected
Discussion in 'Technical Bulletins and Recalls' started by willywill4765, Aug 2, 2017.
  1. willywill4765
    willywill4765 Member
    US
    Hello all again big dog been running pretty well until this past weekend seem to be getting a hissing sound coming out by my air cleaner air filter. Thought it might be gas check the spark plugs everything seems to be good just seeing if anybody out there has got a clue seem to have lost a little power
    Sent from my SM-G900P using Tapatalk
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    First question is has ANYTHING changed or been done? Maintenance included.
    I'd start with changing the sir filter and making sure it's seated properly.
    SKOGDOG likes this.
  3. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Or maybe a vacuum hose
    bdm7250 likes this.
  4. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :agree:
  5. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    how about the little rubber caps?
  6. willywill4765
    US
    No maintenance or anything has been done lately but I will try changing the air filter
  7. willywill4765
    US
    I will check my hoses also
  8. willywill4765
    US
    Not sure what little rubber caps you're talking about can you tell me where they're at
  9. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    should have one just to the forward side of the throttle cables on the top of the carb. they tend to dry out with age and crack and eventually fall off allowing a vacuum leak. looks like the cap on a brake bleed fitting. it points upward.
  10. willywill4765
    US
    It's fuel injected not sure if I would still have the rubber caps somewhere else
  11. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    that i can't help you with, mine is carb. sorry. but take a flashlight and go on a safari, it'll teach you alot about your bike. good luck.
  12. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    This is what you should have behind the air cleaner, See the brass fittings.
    Big D Florida likes this.
  13. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    so, in the blow-up, it appears there are 2 of them. one to the right of #22 and one between #25 and #16.
  14. willywill4765
    US
    Great picture the brass vacuum to the right of #22, my rubber seal is cracked that will probably be my problem I will run to the parts store to get another one thank you so much for all your help
    pknowles likes this.
