2006 Mastiff ignition on while switch is off.
Discussion in 'Technical Bulletins and Recalls' started by flybysr1, Jul 10, 2017.
  1. flybysr1
    flybysr1 Member
    Gibraltar, MI
    2006 Big Dog Mastiff; 2009 1125 Buell
    Rick
    Rode 500 miles this weekend. Tach died, speedo died, turnsignal work. When I tried to turn it off with the key it kept running. Is thei related to the EHC? I need a electrical diagram.
    chubs likes this.
  2. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
  3. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Could be a lot of things, but since your key switch is an obvious problem I'd start there. You can unplug it from the harness behind the coil mount. It's a small JST connector. The key switch is only two wires, so any two connector switch will work. I installed a hidden switch on my 06 K9 and 06 Mastiff a few months ago: http://bigdogbiker.com/threads/install-ignition-switch.79998/
    you could also go to tractor supply and get a new key switch made for a 9N Ford (tractor) but it fits in the hole then splice the two wires that you'll cut off the back of your current key switch that way you still have a key. On mine I left the key switch there even though it's disconnected so it looks like you'd need a key. Get into the link for the thread above and you'll see the backside of the coil and what I'm talking about.
    Once you get that sorted then you can start chasing what else might be the issue.
    Low rider and chubs like this.
  4. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Try removing your key switch and jumping in a toggle switch, if it solves your problem replace your key switch. DOC's has stock BDM switches, I got one last year, very good quality.
    PROFLYER and chubs like this.
  5. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    chubs likes this.
  6. awg
    awg Well-Known Member
    2004 Big Dog Chopper
    And there you go!
  7. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    I got up the nerve to put the required torque on the gas tank mount to get the tank off. It's not the key switch. The tach and speed don't work but the oil pressure and neutral indicators do. The EHC module looks to be original 2006 part made on 6/21/06. Part Number is 171-000002-00. Is this a known bad EHC? It has a strange quirk that if you hit the rev limiter the bike shuts down until I hit the run button... It requires rebooting frequently to get the gauges to work. Any suggestions or insight are appreciated.
    chubs likes this.
  8. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I'm a bit confused...you needed nerves to apply some muscle on a bolt but Hitting the rev limiter at 6200RPM obviously more than once is no problem? It's shutting down cause it doesn't like being up that high...lol
    How many times you hit that revlimiter? These bikes aren't Honda's...
    Gmutoagrsv, BigDogRick, chubs and 2 others like this.
  9. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    U need to replace 7r switch no doubt and go from there.. it may not be the issue, but if it ain't shutting down, it ain't working.. period.. it gives and takes power..
    Here is something that might help the other issues
    chubs likes this.
  10. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    It's happened two or three times. It's not like the tach is any value at shift points. Is that the proper operation? I read that if you shift up and the rpm returns to normal operation, the motor will continue. It doesn't work that way. PS- I wasn't referring to a bolt. It's a rubber mounting bracket that is wedged into the tank. This is my first season with the Big Dog, I'm use to a Buell 1125R.
    chubs likes this.
  11. Th3InfamousI
    Texas
    It should continue but with that said these engines are not designed for high RPM.
    I shift at 3500'ish RPM. If I'm really goosing it might push 4500 but hey that's me. I'm in no rush. I've never even seen Red lights on my tach I couldn't even tell ya if they work.
    chubs and PROFLYER like this.
  12. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    I spoke to Chris at BDM. Bottom line is I ordered a RIP version one since my tank is already off and they had one in stock. I gotta git her right and ready. In two weeks she's going to be in a juryed bike show at the General Motors Tech Center in Warren Mi. :chopper:
    chubs and bigkelk9 like this.
  13. bigkelk9
    07 big dog k9
    Kel
    Chris is a good guy, we had the privilege of throwing a few back with him a few weeks ago and seems to be a solid honest good guy.
    chubs likes this.
  14. ground pounder
    ground pounder Active Member
    Ypsilanti,Mi.
    Big dog 2009 K-9 EFI
    Tom
    Are you sure your starter plunger isn't sticking. Had that problem with the starter running with the key off on a big dog!!!
    chubs likes this.
  15. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    No but it happened to me on a different bike. The starter. Would go every time I pulled in the brakes.
    chubs likes this.
  16. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    Hey ground pounder, I'm downriver grew up in ypsi. We should meet up at depot town bike night.
    chubs likes this.
  17. flybysr1
    flybysr1 Member
    Gibraltar, MI
    Rick
    My new RIP kit arrived today. It didn't come with any documentation so the only reference I can find is the Youtube video showing the kit being installed on a new K9. The video doesn't mention the 40 amp breaker and is quite different than my 06 Mastiff. I've looked at and don't see how to remount the breaker without drilling holes. If anyone has done this installation please let me know what the BDM solution is for the breaker. Everything else seems straight forward ....so far
    chubs likes this.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    It takes a lot to do it with a 3/8" ratchet, but I have found if you use a 1/2" breaker bar with a 3/8" adapter you can turn and control the force it takes to turn it much easier.
    chubs and bdm7250 like this.
