Thank you, I will try and get one!!The 2007 Service Manual says 1/2-20 X 1-1/4 inch SHCS chrome. It should be the same for 2006?
I have the 2006 Service Manual and Huw is correct. 1/2-20 X 1-1/4 inch. Torque to 80 ft lbs with red loctite. I check mine pretty regular. Always seems to come loose after a while.The 2007 Service Manual says 1/2-20 X 1-1/4 inch SHCS chrome. It should be the same for 2006?
Thanks for the tip CurtisTry an "Anti-Vibration" washer on it
