2005 BD Chopper oil lines...
Discussion in 'General' started by Rally, May 8, 2016.
  1. Rally
    Rally Active Member
    Southern FL (Miami)
    '05 BD Chopper, '07 Street Glide
    Hi,
    I have a small oil leak coming from the oil line on the bottom of the oil tank.
    It's not the fitting but the shock has rubbed the braided line into the rubber line. I took a measurement of about +20 inches long on this line. I know that WSW has a four line kit yet it doesn't include a line that is 20" or longer and I've already emailed them.
    Can anyone direct me to what are the oil line lengths required for changing them out?
    I also have the oil cooler installed on my 05 chopper.
    Does the starter and exhaust pipes need to come off to change out the oil lines or what is the best approach in doing the oil lines?
    Thanks in advance
    chubs likes this.
  2. 405bigdog
    405bigdog Active Member
    Shawnee, Oklahoma
    2006 hardly night train
    Chris
    You could probably take it off and take it to a hose company and just have it built while you wait.
    chubs likes this.
  3. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    goodridge was the original manufacturer of the lines. kinda doubt they will do an order of one though.
    chubs likes this.
  4. Rally
    Rally Active Member
    Southern FL (Miami)
    I know that the lines are/were made by goodridge but the lengths are what I'm needing to know.
    Has anyone replaced "any" of the oil lines and know their lengths as the one leaking looks to be just over 20" long.
    Thanks
    chubs likes this.
  5. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    I would contact Derek & Donna on this. They had the right Goodridge brake line I needed to replace the rear brake line. They may have the oil lines as well.
    chubs likes this.
  6. Rally
    Rally Active Member
    Southern FL (Miami)
    So it comes to be the outside braided line (feed line) has a tiny hole that is leaking. Put the line under water with some air pressure and sure enough bubbles come out. To the eye everything looks good but small oil leak non the less. Going to replace it with a rubber oil line for now and back on the road.
    Ride safe
    chubs likes this.
  7. KnotSo
    KnotSo Admin
    Washington
    I take all my steel braided lines to a local company that will do any hose in braided steel, with any curve or options, in the various colors. They mostly do orders while you wait. most every town has such a place
    chubs likes this.
