2005 Arlen Ness Chopper
Discussion in 'Vintage Big Dogs' started by Rick Utley, Jul 18, 2017.
  1. Rick Utley
    Rick Utley Member
    Houston, Tx.
    2004 Big Dog Chopper
    Rick
    I could use some help again I know I'm making a regular habit of this. I have a friend that has an 2005 Arlen Ness Chopper S&S 124 cubic inch I'm helping him work on his bike and first off what kind of clutch is in the picture? Second there is hardly an adjustment left in the clutch even after cable adjustment and inner clutch primary adjustment. Could this be throw out bearing, Bad clutch springs, Bad clutch, [​IMG]what? I'll listen to all takers... Thanks...
    chubs likes this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    How many miles on it?
    What do you mean no adjustment left? If you pull the lever does the plates move at all?
    chubs likes this.
  3. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Bikes has just under 18,000 and when I say no adjustment I guess I stated that wrong. No matter where you adjust it to it starts pulling 1/4" off handgrip...
    chubs likes this.
  4. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    That could be a throw out bearing, but the more I think about it, I think your backing the push rod out to far from touching the bearing. About 1/8 of a turn, should be plenty.
    chubs likes this.
  5. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Well I can sure go back in and change that adjustment & try it...
    chubs likes this.
