2002 Bulldog primary drive belt adjustment?
Discussion in 'Technical' started by 3kingsautomotive, Nov 9, 2017.
  1. 3kingsautomotive
    Arizona
    My big belt seems to have too much slack in it. I can't see a way to tighten it other than increasing the distance between the engine and trans, which would then require adjustment of the secondary belt. Are there eccentric mounting slots beneath either eng or trans? Is it even adjustable? I guess i should Google this shit before looking like an idiot, but i thought maybe someone knows some secret trick or advice? Thanks
    Sent from my SM-G935P using Tapatalk
  2. 3kingsautomotive
    Arizona
    Got it...the open primary. Is there a maximum specification for the slack? I'm in the process of engineering and fabricating a spring loaded tensioner pulley to maintain constant tension. Once completed and tested I'll offer it to others. I don't believe anyone sells such a thing?
    BWG56 and chubs like this.
  3. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    My primary belt is pretty tight, never even thought it would stretch so much I would need a tensioner.
    chubs likes this.
