2-1 exhaust install
Discussion in 'Help Wanted' started by Gmutoagrsv, Nov 1, 2017.
  1. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    Hey everyone. I’ve been searching all over the site but coming up empty. I took off my v&h 2-2 and my new 2-1 should be here in the next few days. Now I’m curious how I get the flanges over the studs. With the 2-2 it was easy. Of course because each side came off individually. And ideas or input.
  2. woodbutcher
    Staff Member Lifetime Supporting Member Full Member Supporting Member
    hilton head is., sc
    black cherry '07 K9
    Tom
    don't know for sure, but, would say that the head pipes are still individual and the aft section will connect onto the head pipes with it all being covered by the heat shields.
  3. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    Should line right up. Make sure you use new gaskets and don't get too torque crazy on the head studs--they can strip out of the head. Get it on and put both nuts on a few turns on both sides and then get the bracket on with the bolts. Basically you want to get it all in place with everything loose, and then torque down to spec the nuts on the heads and then the bracket. I like to put the head studs down finger tight and then two turns on each side working back and forth until it's tight. I'm sure there's a specific sequence but that's how i've always done it. Kind of working back and forth until both sides are tight and the bracket is still aligned.
    Oh make sure you put some red loctite on the bracket bolts or use good washers/nylocks. They like to work themselves loose.
    #3 PROFLYER, Nov 1, 2017
    pknowles, Unsprung and dentdude36 like this.
  4. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    Sutton
    that's my favorite pipe ever made. You don't have it still do you??
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :disappointed:
  6. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Got them put on. [​IMG][​IMG]
    Rottweiler and Tomtang like this.
  7. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    I would recommend blue loctite on the bracket bolt. Red can be a Bitch to remove
  8. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    There is no bracket I’m going to remove those bolts since the pipe floats. I was also wondering if anybody has polished or cut or sanded On pipes that are ceramic coated. Would it do any harm?
  9. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    Sutton
    Those are cool pipes! Who makes them?
    And I can't tell from the pic, but you're playing with fire if that bike isn't strapped to the lift.
  10. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Btw, torque specs are 18 ft lbs with anti seize..
    PROFLYER and chubs like this.
  11. bigkelk9
    07 big dog k9
    Kel
    And recheck after a ride at running temp
  12. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    I am drawing a blank on his name but it’s Exotic choppers. He made them and it took about a month till they were in my hands. He was awesome to work with.
  13. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Cyclops.
    http://www.exoticchoppers.com/CYCLOPS.html
