'16 K9 oil leak
Discussion in 'Motor' started by Sleekride, Nov 19, 2016.
  1. Sleekride
    Sleekride Member
    Teaneck, NJ
    '16 K9
    Jay
    After riding 130 miles and running out of gas, fortunately the reserve did it's job, I found the following leak while refueling. Looks like engine oil is coming down on the frame side of the drive belt housing. There were no leaks on the floor prior to my departure today. I'm still in the break in stages as the bike only has 280 miles as of today. What do you guys think? Attached the video on a YouTube link as I was unable to directly
    load it here.
    chubs likes this.
  2. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Hard to tell where it's from, you say it looks like from behind the belt drive, are you absolutely sure it's motor oil and not gear oil? Cause it's a good possibility that it is coming from your transmission seal.
    bdm7250 and chubs like this.
  3. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    I doubt it is tranny oil, with only 280 mile the tranny oil would still run clean. IMO
    I would check all the oil tank pipe work fittings.
    TapioK, BWG56, chubs and 1 other person like this.
  4. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Good point Jeff, I just didn't think that there are any fittings near that area, and if they are leaking wouldn't it drip right off the fitting itself? If it is one of the fittings then he should be able to fire it up to see if it leaks while parked, if not then and it only leaks while riding then maybe it could be a seal.
    BWG56 and chubs like this.
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Gotta remember he was riding it so even if it came from the oil line fittings it would blow back from riding:yesnod:
    bdm7250, chubs and cdogg556 like this.
  6. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    That's true, but if it don't leak while sitting and idling then it most likely ain't gonna be from the oil lines.
    chubs likes this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    1000 rpm's no leak, 3000 rpms spraying all over the place, :eek: and if its coming outta the tranny the belt should've thrown it on the back wheel also, ax me how I no's dat
    bdm7250, Viking, chubs and 1 other person like this.
  8. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Well Jay, twist the f'n throttle and see what happens! :oldeek: Just kidd'n! :oldsmile: It's a brand new bike, I am sure he has a warranty on it, take it too the dealer and hab's them figure it out.:old2:
    bdm7250, chubs and BWG56 like this.
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's the smartest thing you said all night[​IMG]
    bdm7250, TapioK, chubs and 1 other person like this.
  10. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
  11. Sleekride
    Sleekride Member
    Teaneck, NJ
    '16 K9
    Jay
    All good points fellas. Thanks for the input. Dealer's 1,400 miles away and it does have a warranty so I'm in a bit of a quandary. Guess I will strap her onto the J&S jack and rev her up to test out some theories.
    cdogg556, bdm7250 and chubs like this.
  12. Viking
    Viking Biker
    Florida
    Check all fittings of the oil lines, I'm pretty sure that's where it is. A new nipple can be a PITA.
  13. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Need a better camera haha..have a hard time seeing it.
    cdogg556 and chubs like this.
  14. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    X2:old2::agree:
  15. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    Jay wipe her all down first, do a quick check on the fittings, pack up the stand or put on a lift and start her up.
    Once warm do a check for leaks, if none found.
    Go for a ride say for 5 min, check again road side.
    One thing i found on mine one time was the primary vent spewed out oil cause i over filled it.
    If this has happened there will be a drip under the primary as well.
    Good luck.
    cdogg556, chubs and Viking like this.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    This dealer is a little closer, there's a shop by me that was interested in becoming a dealer for Big Dog but they never replied to his messages he left them, so he said the hell with it.
    Street Stuff Cycle
    4 Central Ave
    Norwich, CT 06360
    860-886-5902
    streetstuffcycle.com
    cdogg556 and bdm7250 like this.
  17. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    that connection from braided to hard line right there is crimped is it not???? could be faulty from the manufacturer. know it should have been pressure tested but some times they can get past without showing obvious signs of failure.
    bdm7250 likes this.
  18. Chateau Slate 66
    Minneapolis, MN
    2009 Big Dog K9
    Andy M.
    I agree with several of the above statements. Wipe everything down and take a close look at all the oil piping. Be very careful if you are going to rev the bike on a lift. No sense turning an oil leak into a bike laying on the ground.
    I had a loose fitting at the engine that dripped on the frame and ran back to that area myself. It can be very deceiving where the leak originates and where it shows up. I've used UV dye for the really tough ones, but you can cross that bridge later if needed.
  19. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    The frigid winter of Boston is getting to ya...it was already mentioned the dealer is 1400 miles away..:oldhardlaugh::oldhardlaugh:
    cdogg556 and dentdude36 like this.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :nonod:
    Freakin meat head don't read nuttin :oldhardlaugh:
