117 upgrades
Discussion in 'Motor' started by Jeff Taylor, Apr 29, 2016.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    chubs likes this.
  2. vej
    vej Active Member
    Land O Lakes Florida
    08 Mastiff Limited Ed.
    UPDATE: Seems after my top end rebuild (cometic gaskets and heads milled .030 for a total drop of .053), the pre-ignition no longer seems to be occuring... or at least I really don't hear any pre-ignition now!
    chubs likes this.
  3. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    I recently installed the TH programmable ignition on my 05 117. I have V&H pipes. Before the bike would strain to get to and above 4500 rpm. Now it pulls through 5000 and is smoother at it.. I try to stay above 3k but did not notice much difference between 2500-3500. 585 cam next.
    chubs likes this.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I did the opposite, 1st was the 585 and that was huge, and you will hear the difference the first time you fire up the bike with that cam in it, I installed the TH at the same time I did the 585 cam. I'm waiting until I come across a Dyno to try the different timing settings to see the results.
  5. Viking
    Viking Biker
    Florida
    There it is! The absolutely craziest idea on here ever. We all know that TP rocker boxes are way faster than S&S boxes, just like silver paint is way way way faster than red ones. Come on man.....:oldhardlaugh::oldhardlaugh:
  6. Viking
    Viking Biker
    Florida
    Ever heard of a XXX carb? Add the Tasmanian Devil to it and with a new cam as suggested above you'll have enough power to not being able to hang on to the bike.
    I know, no more new XXX, but there is plenty of them out there....
    bdm7250, chubs and dentdude36 like this.
  7. Roaddawg
    Roaddawg Well-Known Member
    Full Member
    New River, AZ
    2005 BDM Chopper; 2014 HD Ultra Classic
    Bruce
    OK, remember, there are two variables here, Horsepower and Torque. Horsepower is defined as how fast your are going when you hit a brick wall. Torque is defined as how far you travel through the wall after hitting it.....
  8. malc
    malc Member
    coventry
    bigdog chopper,harley fatboy
    malc
    What do you mean open up the exhaust and inlet,I fitted the 585 cam and ignition,and getting really bad backfiring.thx Malc.
    Sent from my HTC One_M8 using Tapatalk
    SEAL-rider and chubs like this.
  9. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Aftermarket intake (usually the mounting plate), bigger carb jets, and exhaust that allow more air/fuel into the engine and more exhaust out. Compliance with EPA regs on stock intake and exhaust require restricted (and lean) air/fuel flow through the engine for optimal (EPA) emissions. Putting on pipes with less restrictive baffles (louder too) and a larger intake capacity increases power.
    If you put in that cam and exhaust, the rest should have been done too.
    Decel popping has defeated better men than me, and is an oft-discussed topic on the Forum. Any search will find lots of threads addressing it. It can be due to any of a number of factors including timing, loose intake manifolds (leaks), improper carb jetting, and so on. I simply learned to appreciate decel popping-- my bike runs great with a TH, 585 cam/V&H 2-2.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I also added the Dual runner when I installed the 585 also and it sounded like a machine gun accelerating and decelerating, I also had to rejet the carb and I used S&S's carb guide lines for setting the carb. And I removed the bowl vent screw
    Big D Florida, chubs and bdm7250 like this.
  11. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :agree: I had some additional head and valve work done, added a 630 Woods cam, dual runner and V&H 2-2.
  12. SEAL-rider
    Del Mar, CA
    Spencer
    585 installed and like the ignition installed a couple weeks ago it provided improvements. Longer flatter torque curve and minor power increase. The smoothness both low, mid and high rpm are not minor. 4500 rpm is now smoother than 3k was before the two upgrades.
    chubs likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Do you have a dyno sheet to see the improvements?
    cdogg556 and chubs like this.
  14. SEAL-rider
    Del Mar, CA
    Spencer
    Noy yet. But, before the engine would gasp for air and fuel above 4500 it now pulls smoothly through 5500. Thr power gain may be greater than what I feel, but even without power gains the bike rides considerably better than before. Curtis recommends I get the dyno and I woll soon. I need to decide if I am going to stay with the E carb or switch to Mikuni before I dyno it. I don't want the expense of switching manifold and G carb. I am hoping a Mikuni 45 will fit and get the job done. I don't have plans to do heads or 600 cam.
    chubs likes this.
  15. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    The guy who builds the xxx taz carbs sells them on eBay he has 4 different carb models to choose from depending on how extreme you want to get they are all built out of super G or Ultima R1 crabs. Also installing a set of big city thunder baffles can help with the decel pop they sell online for $79.99 you also get a lot better sound with them also and they help improve your torque curve.
  16. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    I gotta ask ya, how is your low end with that 630 cam Douggy? :oldconfused: And are you like the other wankers around here that install cams and never rev it past 4,000 rpm? :crazybitch: It just seems like anything over the 585 would be useless unless your gonna build it up to rev the shit outta it, my 585 pulls like hell with no end in sight right to the rev limiter which is supposedly 6,250 rpm! :whoop::whoop::whoop:
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That explains a lot, when are you going back in to get the rest of it fixed :willynilly: :oldlaugh:
    bdm7250, bigkelk9 and chubs like this.
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That's why your replacing head gaskets:oldbang: :willynilly: :yesnod: :oldhardlaugh:
  19. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    :job::job::job:PUSSY! :oldhardlaugh:
    Big D Florida, chubs, bdm7250 and 2 others like this.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldhardlaugh::oldhardlaugh::oldhardlaugh:
