The stock valves that were in my 04 were 2.0 for the intake and 1.605 for the exhaust, which is the stock size for a true 117 S&S. The builder johnsachs in this thread is using a 2.020 intake valve with his builds. As far as I know I would have to say that 10.8 maybe 11.0 would be the limit on pump gas. I'm running 10.8 and the timing at 28 BTDC. If I throw any more than that at the advance it will start to ping.What size is that? The reason for the questions is that I am thinking about a bigger intake valve. And I would like to go to around the 11- 11.2 to one or so. I asked this question before but I don't know how high a guy could take the compression and still run 93-94 octane? I would like to take it to that piont. The valve I was thinking of would be 2.2 or so.
Are you running race fuel in yours Marv? 11.9 sounds high for the pump gas if that is the case.
Free flowing pipes will cause a dip in the 2000 rpm range. The ripple in the graphs would indicate that either you have a pushrod that isnt quite adjusted right or you have some slop in your primary chain.Everyone:
I have attached a dyno sheet that shows some fairly respectable numbers. Testing was taking in Nebraska at 2,800 ft of elevation.
The baseline numbers are a 117 with a S&S 600 cam, XXX Carb, V&H 2 into 1 pipe, and powerpacc carb backing plate.
The new results are after changing to a woods 650 cam and springs, Hooker Fourbidden pipe, zero deck height, and Thunderheart Ignition.
A note worth mentioning, is we dyno'ed the bike using the 3, 4, and 5 settings on the ignition and it showed only a small difference between the 4 and 5 but it did not like the 3 at all.
These are numbers with the air filter on, we did gain 3 hp and 2 tq by taking off the air filter
The dyno guy did say the dip is due to the engine needing more back pressure and the normal problems associated with running an Super g carb.
Life's good, run's great
K9 Husker
Very nice relation!:up:Head work it good, makes it breath better. Need good air filter too. A motor is alot like a BJ. The better the girls breathes through her nose(air filter) as she is doing the deed, the better(never comes up for air) and faster she she gets the prize. By the way, I run a 650 woods cam.
I agree with BDLook at his before torque graph. It has a more normal curve without the pronounced dip and he was using a 2 into 1 exhaust. His major changes were the cam and exhaust. With the larger cam exhaust tuning becomes even more critical.
He should try swapping exhaust to the previous 2 into 1 and redyno or just go for a ride. I bet it is a night and day difference.
