CURDOG
I've read a lot of the EHC threads and I hope my EHC is not defective because I'd like to keep my bike stock but my intermittent problem on my 08 K9 has finally become permanent. Here's what I have....
My bike's always garage kept and always on a tender, I do all my regular maintenance and the only problem I've had (other than this one) was when I first installed a HID headlight but after working through that problem, nothing but problem free riding until recently. My bike currently won't start at all and the first thing I did was remove the HID and replaced it with a stock bulb, thinking that may be the problem.....it wasn't.
In testing, here's what I have:
Battery voltage - 13.15v, all connectors checked and cleaned, bolts tight.
Key on - headlight comes on, speedo sweeps to 60mph and back, green (controller) light on EHC flashes and amber (power) lights comes on steady
Press Run button - Red (ignition) LED on EHC lights up.....so far, so good
Press Start button - compression releases click but starter doesn't engage
I unplugged the green wire to starter solenoid, key on - 4.7v, Run button pressed - 4.7v, Start button pressed - 4.7v
I've disassembled the handlebar controls and inspected and Di-greased, I've unplugged the EHC connections and Di-greased them, checked starter ground.....all clean and visibly fine. All lights and turn signals work fine.
Anyone have any ideas? The flow chart for the starter solonoid says there should be 8 volts standing at the starter solenoid (green wire) so I'm thinking that may be the issue.
Thanks in advance.
Thanks in advance.
