04 Big Dog Chopper
Discussion in 'Fluids!!' started by Rick Utley, Aug 18, 2017.
  1. Rick Utley
    Rick Utley Member
    Houston, Tx.
    2004 Big Dog Chopper
    Rick
    Would someone please give me some input on tranny fluid for my 04 Big Dog Chopper six speed baker. I didn't change it last and it looks like ATF coming out and it's frothy like and I bought Harley primary transmission fluid to put in. Ideas opinions please... Thanks
  2. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I use Royal Purple synchromax.
    Big D Florida likes this.
  3. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Ok so next time I can do that but I have already bought HD primary tranny fluid you think this is ok for a bit? And do you know exactly how much to put in? Is it a quart?
  4. bdm7250
    bdm7250 Guru
    Doug
    I'm sure it would be fine, 20oz in tranny.
  5. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I hate to say but I put anout 28 oz and it's just very slightly above full reckon that's ok
  6. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    paul
    You can pull some out with a section of rubber hose.
    bdm7250 likes this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    This is what I use and 20 Oz, it is pinkish
  8. bdm7250
    bdm7250 Guru
    Doug
    Shouldn't you be getting that Stabil in the industrial size, the only mileage you get is on the Deere...:oldhardlaugh:
  9. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Well that's probably what was in it. You reckon it's still ok to run HD primary tranny fluid once till I can get some spectrum syn
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The primary oil is only 30w if that and the tranny oil is 75-140, if it was mine I wouldn't.
    TapioK and Big D Florida like this.
  11. Big D Florida
    Supporting Member Troop Supporter
    I like Lucas products, but have heard good things about others , as well. You'll probably get several opinions on brands. There are several threads on fluids.
    Regardless of what brand you choose... PK hit on an important issue, best to go with specified amounts in each compartment, and correct your overfill.
    You can also put a plastic tube on a turkey baster to extract excess fluids/oils/spit?
  12. Matheny 514
    Matheny 514 Active Member
    Auburn, Alabama
    2005 Big Dog Ridgeback
    Justin
    BWG56 likes this.
  13. Matheny 514
    Auburn, Alabama
    Justin
    :agree:
    BWG56 likes this.
  14. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    I'll change it tomorrow
    BWG56 likes this.
  15. Matheny 514
    Auburn, Alabama
    Justin
    As Big D and PK said above, you don't really want to overfill with the oils. Go with the exact amount, (20oz in transmission).
  16. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Will do
  17. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Sounds like you had Red Line in the trans. It's red and kind of foamy. It's good stuff.
  18. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Ahhh does HD sell this stuff?
  19. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    FYI, the reason everyone is telling you to make sure you have only 20oz. in the tranny is that if you overfill, it will destroy the seals from the tranny into the primary. which will allow for cross-migration of the fluids, not good. and another vote here to use either the redline or the spectro.
  20. Rick Utley
    Rick Utley Member
    Houston, Tx.
    Rick
    Gonna make the change today and all the help and advice is greatly appreciated...
