Milco
The Flying Dutchman
Is this one really plug and play for a K9?
https://www.amazon.com/dp/B018LXCV4U/ref=cm_sw_r_cp_apa_Pd0MAbC2992FX
That one is the one and there's also a chrome one without the black backing which I think looks betterIs this one really plug and play for a K9?
It's got the same exact light output/Lumens (4000) so it's got the same brightness as the sunpie. It actually doesn't list it's lowbeam on the website.Look into this it's much brighter and extremely high quality
https://www.amazon.com/gp/product/B...f6b-5f5f-b4b8-9e55854fb467&pf_rd_i=8323665011That one is the one and there's also a chrome one without the black backing which I think looks better
Yes Sir...i have that one in both bikes. One has about 6k miles the other gas 2k both no issues.
Thank you!, and does this also solve the problem with the burned headlight connector?Yes Sir...i have that one in both bikes. One has about 6k miles the other gas 2k both no issues.
The OEM plastic connector shouldn't melt as the current is much lower BUT I would still replace it when you got it apart anyways just incase. No reason not to put a ceramic one in the headlight regardless. Who knows once you get it apart it could have been replaced anyways already.Thank you!, and does this also solve the problem with the burned headlight connector?
OK thanks again! I will look where I can purchase the ceramic one!The OEM plastic connector shouldn't melt as the current is much lower BUT I would still replace it when you got it apart anyways just incase. No reason not to put a ceramic one in the headlight regardless. Who knows once you get it apart it could have been replaced anyways already.
www.wildsteedworx.com/index.php?main_page=product_info&cPath=68_173_82_100&products_id=219&zenid=9rlsjmcbcffehesh4ua8kih0t7OK thanks again! I will look where I can purchase the ceramic one!
http://www.lamonstergarage.com/lamo...light-for-f3-st-parts-accessories-motorcycle/
The light pattern on the daymaker probably makes it seem less but it's the same.
