Unsprung
In the Potters hand...
Ker, I have the stock cleaner cover which it will hit if moved forward. May have to change that but I actually like the OEM cover.Does your leg hit it?
Can you move it up into the front and middle holes?
I also like the stock cover and you might consider having it painted to match the scoots paintKer, I have the stock cleaner cover which it will hit if moved forward. May have to change that but I actually like the OEM cover.
Damn, I do remember someone saying that, BummerKer, I have the stock cleaner cover which it will hit if moved forward. May have to change that but I actually like the OEM cover.
Is that at the pressure sensor John? I don’t see your sensor...why don’t you clean that motor a little?That's exactly why I did mine like this....View attachment 51939 View attachment 51940
If it does not work for me, it’ll work for someone else Ker, or a little modification to suit my needs.Damn, I do remember someone saying that, Bummer
Look at Cdogs first pic, you can see the sensor aside itIs that at the pressure sensor John? I don’t see your sensor...why don’t you clean that motor a little?
Kit comes with an adapter to fit the line and switch together. Had to remove the exhaust for better reach but simple install really.How was the process installing the line to the pressure switch?
Not sure what you mean, the first pic you can see the gauge and the sensor on the left side, the gauge is mounted on top of the tappet screen.Is that at the pressure sensor John? I don’t see your sensor...why don’t you clean that motor a little?
I know Gerald, I should have never took the pic when it was so filthy!Is that at the pressure sensor John? I don’t see your sensor...why don’t you clean that motor a little?
Only saw one pic at first, actually had a follow up question until I realized there were two pics. Thanks John.Not sure what you mean, the first pic you can see the gauge and the sensor on the left side, the gauge is mounted on top of the tappet screen.
John that is the exact oil pressure gauge that I just bought. Yours looks great!Not sure what you mean, the first pic you can see the gauge and the sensor on the left side, the gauge is mounted on top of the tappet screen.
That looks great! I just bought one today!I found them on the Spyder forum, they come in sets and I have them in my F3. Dent and I split a set and the nice thing about this LED is the H4 mount is adjustable and locked in place with set screws and no moving parts, like a fan.
View attachment 50785 View attachment 50786
Oh my God! I despise polishing my engine! Lol I wish mine was diamond cut and powder coated. I'm thinking about having that done this winter.Finally I installed my oil pressure gauge and figured I’d get some polishing done. Engine polishing sucks, wish it was chrome. View attachment 51930
Dentdude’s the man when it comes to polishing. I still need to get on it. By the way I installed the gauge like Ker and John did.Oh my God! I despise polishing my engine! Lol I wish mine was diamond cut and powder coated. I'm thinking about having that done this winter.
Or like thisOh my God! I despise polishing my engine! Lol I wish mine was diamond cut and powder coated. I'm thinking about having that done this winter.
Right on Gerald! When you get a chance post a pic of it! Make sure you clean it up before! Haha!Dentdude’s the man when it comes to polishing. I still need to get on it. By the way I installed the gauge like Ker and John did.
